crossing over bi-amped tweeters
ilikesound
what is the LOWEST safe operating range of the mmc6500 tweeter? i know i should avoid going below a certain frequency as to avoid damage...
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
Post edited by ilikesound on
on how much power?
It depends on the slope.
If youre using a 30 db slope then you could go down pretty low.
Either way, I wouldnt go below 3 KHz.polkaudio sound quality competitor since 2005
im biamping using my c400.4, so i suppose 75 rms to them. the birth sheet says 98watts, so im unsure if that's per channel or for a set of channels. either way does it make a difference how many amps are running to it?
and also im not sure which slope to use, 12 or 24db/oct
do the midrange and tweeter's slope have to match? what's the difference if you slope them differently?
last question: how far does the midrange frequency extend? doesn't sound like it would blend with the highs very well, demoing it by itself...ok, im done now lol.At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
stock system in new car for now:( -
The slopes do not have to match but I would use the 24db setting. It creates a quicker roll-off. As you can see in the graph the higher db cuts off the frequency sharper. That is ideal. I will have Kim post on here as well. He has more specs on the individual speakers than I do.
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
