crossing over bi-amped tweeters
ilikesound
ilikesound Posts: 355
edited June 2007 in Car Audio & Electronics
what is the LOWEST safe operating range of the mmc6500 tweeter? i know i should avoid going below a certain frequency as to avoid damage...:confused:
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Post edited by ilikesound on
  • exalted512
    exalted512 Posts: 10,734
    edited June 2007
    on how much power?
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2007
    It depends on the slope.
    If youre using a 30 db slope then you could go down pretty low.
    Either way, I wouldnt go below 3 KHz.
  • ilikesound
    edited June 2007
    im biamping using my c400.4, so i suppose 75 rms to them. the birth sheet says 98watts, so im unsure if that's per channel or for a set of channels. either way does it make a difference how many amps are running to it?
    and also im not sure which slope to use, 12 or 24db/oct
    do the midrange and tweeter's slope have to match? what's the difference if you slope them differently?
    last question: how far does the midrange frequency extend? doesn't sound like it would blend with the highs very well, demoing it by itself...ok, im done now lol.
    At Home:
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Away From Home:
    JVC HDR-50
  • [Deleted User]
    [Deleted User] Posts: 763
    edited June 2007
    The slopes do not have to match but I would use the 24db setting. It creates a quicker roll-off. As you can see in the graph the higher db cuts off the frequency sharper. That is ideal. I will have Kim post on here as well. He has more specs on the individual speakers than I do.
