50/35 foot dDMI
Systems
Systems Posts: 14,873
I need to run a 35 to 50 foot HDMI (ya, I see I fat fingered it in the title) cable for my front projector. When it comes to HDMI, do you think I’m gonna have any problems with the video with one of these. I want it looking perfect 1080P.
Testing
Testing
Testing
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    I use the premium version at Monoprice 50 FT. The only problem with HDMI is it doesn't lock so it can slip out of the projector and or the DVD player.
    engtaz
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    I think that HDMI can do that length, That is a long run for video though...I know they make signal amplifiers for HDMI cables somewhere...It also depends on the quality of cable you are using....
    Here is a link to one of the signal amplifiers....It's actually a repeater...
    http://www.markertek.com/SearchProduct.asp?item=OMX%2DHDMIREP&off=0&sort=prod
  • louthewiz
    louthewiz Posts: 581
    edited June 2007
    Try and run the cable first and test it out it should work just fine,
    If there is going to be any signal loss then it will be over 50 ft.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
