50/35 foot dDMI
Systems
I need to run a 35 to 50 foot HDMI (ya, I see I fat fingered it in the title) cable for my front projector. When it comes to HDMI, do you think I’m gonna have any problems with the video with one of these. I want it looking perfect 1080P.
Testing
Testing
Testing
Testing
Testing
I use the premium version at Monoprice 50 FT. The only problem with HDMI is it doesn't lock so it can slip out of the projector and or the DVD player.engtaz
I think that HDMI can do that length, That is a long run for video though...I know they make signal amplifiers for HDMI cables somewhere...It also depends on the quality of cable you are using....
Here is a link to one of the signal amplifiers....It's actually a repeater...
http://www.markertek.com/SearchProduct.asp?item=OMX%2DHDMIREP&off=0&sort=prod -
Try and run the cable first and test it out it should work just fine,
If there is going to be any signal loss then it will be over 50 ft.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
