Is it worth getting a separate amp for my setup?
tcrossma
tcrossma Posts: 1,301
edited June 2007 in Electronics
I have a Yamaha RX-V2500 receiver, Polk T90e (Monitor 60) fronts and Monitor 30 surrounds. My receiver is listed at 130W/channel. I have been reading a lot on this forum and the general consensus is that a separate amp is the way to go.
But, I don't have particularly expensive speakers, so will I benifit from a separate amp or should I just stick with things the way they are?
thanks,
tim
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited June 2007
    Are you happy with what you have? If so, then no. Do you have a friend that has a separate amp set up or a local Hifi shop you could visit to hear the difference.
    You might just change your mind!
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • janmike
    janmike Posts: 6,146
    edited June 2007
    Hi Tim and welcome.
    I have never owned the Monitor series speakers but I would say you are ok. I did own a Yamaha RX-V1500 and drove RTi100's, CSi5 and RTi6's with no problem. After I went to the LSi line, ALL the gear changed and I went the separate way.
    Michael ;)
    NORTH of 60°
  • tcrossma
    edited June 2007
    SLOCOOKN wrote: »
    I'm happy enough I suppose, but without doing a complete overhaul of all my speakers if I could do better by adding an amp I might consider it. I don't have any friends that could help, but I suppose I could try a local shop. But if my speakers were too low to even *potentially* benefit from a separate amp i'd stop thinking about it :)
    thanks.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited June 2007
    tcrossma wrote: »
    thanks.
    You are now engaging the dangerous addiction called "upgradeitis" to which there is only one cure.....ENJOY, GOOD LUCK, and just ask if you have anymore questions. As you can see, if it has been made someone here has experienced it.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I have the same setup as you, more or less. My AVR is an HK with less rated power, but I'd guess they are somewhat comparable.
    I don't think your current AVR would run out of headroom with your current speakers and probably does well for HT. The 2500 is a pretty beefy receiver, my GF's dad has one.
    An amp may bring a bit more punch, clarity, musicality, etc. but I wouldn't think it would be night and day. I've experimented with a number of amps in my setup and think they are an improvement over just the AVR, but not a HUGE difference. Noticeable and worth the investment for me, tho.
    Maybe get a stereo amp and try it on your fronts. You can get one for a couple hundred and resell for the same if you don't like it.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • MSALLA
    MSALLA Posts: 1,602
    edited June 2007
    I don't know if it would be that big an improvement. That is a pretty balanced setup you have. If you have a case of upgradis get an amp and start your addiction. I bet the next thing will be speakers.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2007
    Expensive is in the eye of the beholder Tim.
    My speakers weren't very expensive, and they are old to boot! But the difference between them being powered by 110wpc Denon receiver & being powered by 200 & 405 wpc separate amps made a HUGE difference!
    I firmly believe that all speakers benefit from separate amplification. Most who have gone that route have come back & confirmed that theory.
    So check out our own Flea market when you have the required posts or start looking at Audiogon for separate amps. Rotel, Parasound, Adcom, Nad, Sunfire, & Outlaw are all good brands to take a look at.
    If you have tower speakers, I always recommend 200wpc to get the best out of them.
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    I had the same same thing happen with my setup."But the difference between them being powered by Denon receiver & being powered by 200 & 405 wpc separate amps made a HUGE difference!"cfrizz
    engtaz
  • tcrossma
    edited June 2007
    Thanks everyone, lots of food for thought here.
    Incidentally, what's the "required posts" for the flea-market?
  • AndyGwis
    edited June 2007
    twenty five
  • MikDrago
    MikDrago Posts: 18
    edited June 2007
    My system is also similar to yours although I have Monitor 50's front, 40's rear and a CS1. I use an HK AVR 520 and a five channel HK PA5800. I loved the way the system sounded with just the receiver but after adding the seperate amp there was a noticable difference in the overall sound. More bass, clarity and less strain. It sounds more efficient and clean. I bought the amp used on ebay for 200 dollars so it was definately worth it. It can't hurt to add a good quality amp to your system, especially if you ever upgrade your speakers.
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2007
    you're fine. If you're not happy with the sound, then upgrade the speakers.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • McLoki
    McLoki Posts: 5,231
    edited June 2007
    I do think you will see benefits from your speakers by upgrading to an amp. With that being said - I do not think the amp is your weak link. (i.e. - while you will see some benefit, you will see more putting your money elsewhere in your system.
    If your plan is to next jump into LSi's or similar level speaker - get the amp. (it becomes just a step in the upgrade that way) If you plan to keep the rest of the system you have and just want to upgrade something, list the rest of your system and your budget, and we will vote on how to spend your money... :D
    Michael
  • cfrizz
    edited June 2007
    He will most likely hear a very good improvement from his speakers with additional power, and it might be enough to content him with what he has for a few years. (It has certainly done the trick for me with my speakers.)
    And he will be in a very good position to get the best out of whatever other speakers he may get somewhere down the line.
    Just because the speakers didn't cost an arm & a leg doesn't mean they aren't worth trying to get the best out of them with separate amplification.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2007
    Even R50s benefited from a separate amp, but as others said, I think you'll get a better bang for your buck by either moving up with your speakers or buying a nice sub.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • mantis
    mantis Posts: 17,316
    edited June 2007
    McLoki wrote: »
    Michael
    I agree with this advise.
    By the way the Yamaha got alot of power and is a pretty decent receiver to drive those speakers. You could step up to RTI (which is a small step ) and still be fine. If you go Lsi then you will need a multichannel amp.
    Good luck with what you do.
    Dan
    Dan
  • tcrossma
    edited June 2007
    Thank for the info everyone.
    Here's the rest of my system, in case anyone has any recommendations as to what to upgrade next (noting that i'm not looking to spend money just for the sake of spending money)
    Receiver: Yamaha RX-V2500
    Fronts: Polk T90e
    Center: Polk CS2
    Surrounds: Polk Monitor 30
    Sub: Paradigm Ultracube 10
    DVD Player: Toshiba SD-4900
    Power center: Monster HTS 3500 Reference
    TV: Panasonic 42" Plasma
    Thanks for the input everyone.
    tim
  • McLoki
    McLoki Posts: 5,231
    edited June 2007
    Bad news - your system seem really well balanced to me. Are there any glaring flaws you are trying to fix? It really seems like if you want much of an upgrade, you are going to have to go in for a major overhaul. (Since there is no really glaring weak link)
    To get the most out of what you have, I would spend some time researching room treatments and calibrating your system. (not just balance the levels, but calibrate your display - map out the frequency response of your sub to see what the room is doing to it) also investigate some room treatments that would not only improve the sound, but hopefully work with the room from a WAF standpoint.
    Other than that - you have a great system, enjoy it.
    Michael
