Anyone using Vga switch box?
engtaz
engtaz Posts: 7,674
I am hooking up a Media PC and Xbox360. What is everyone else using?
engtaz
Post edited by engtaz on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited June 2007
    Cables to Go has a couple of decent ones, and Aten makes a few as well. If you need a specific model, I can come up with one for you.
    Tschüss
    Zach
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    I am switching the VGA to my projector manually. Even though it is a pain to unplug the VGA cable, I found that many VGA switch boxes degrade the signal quality a LOT. Some of the VGA switchers they sell at www.microcenter.com work quite well, but still degrade the signal.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
