Quick Crossover Rebuild Question
riglehart
riglehart Posts: 276
edited June 2007 in DIY, Mods & Tweaks
I'm doing my 11TL crossovers. I noticed in many pics here that people appear to glue their parts down with hot glue (clear plasticy looking stuff). Is this special stuff, or does any run-of-the-mill hot glue gun work?
Or, is it something else?
I'll post pics when done.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    Regular hot glue is fine;) I have also used foam weather strip tape with good results under my caps. Don't worry about resistors. They can get hot so leave them attached by solder only.
    Ben
  • george daniel
    george daniel Posts: 12,096
    edited June 2007
    I just use regular hot glue stick in my gun from the hardware store,,the ones that you would use for crafts,,etc,,good luck and have fun.
    billbillw Posts: 7,448
    edited June 2007
    You can also use silicone. That's what I've used. It seemed closer to what was on my original (Mirage) crossovers anyway. I also find that it stays flexible and its easier to apply than hot glue.
  • riglehart
    edited June 2007
    Here they are. Before and after. I went the cheap route on the 33uf capacitor. This job was $36 for both crossovers. Using Solen 33uf would have doubled it. I can pop those in later, if I get the itch. I used the Dayton resistor because Parts Express didn't have Mills in 2.7Ohm. I did use the Mills 2ohm.
    They sound WAYYY better. I think these had issues when I got them. I hadn't used them much, but always suspected something. The resistor that was brown on top had ash underneath it. It was toast.
    Anybody who can hold a solder iron could do this. Don't be intimidated if you've been thinking about it.
    Jolida Tube
