B&K Ref 20 pre-pro
AndyGwis
AndyGwis Posts: 3,655
edited June 2007 in Electronics
I just picked up a B&K ST-1430 recently, and have come across a couple nice B&K Ref-20 prepros. Not 100% sure I want to make the jump to a pre-pro from my HK 635, but it is tempting to say the least.
Anyone have experience with this piece? What might I expect going from using my HK 635 to the Ref 20? What is a fair price for one in very good condition?
Thanks! I love my HK 635, but I am a sucker for B&K gear (have owned two amps and a preamp of theirs with great results). So much for not upgrading my HT. . .
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
Post edited by AndyGwis on
  • mantis
    mantis Posts: 17,378
    edited June 2007
    The Ref 20 is a fine preamp. It's also upgradable to the ref 30 spec's. B&K allows you to send it in and get it over hauled. It's sweet.
    I'm not sure on a good price for it... maybe 600.00??? If you can get one cheap enough, I'd say go for it.
    Dan
  • AndyGwis
    edited June 2007
    I can get one off Agon for $400 + shipping. Sound like a good deal? Basically would be trading my HK 635 for the Ref 20 as I think $400-$450 is about what I'd get for the HK.
    B&K will upgrade it to a Ref 31 for the awesomely affordable price of $988 + shipping! What a deal! Maybe they aren't aware the Ref 30 can be had for much cheaper, and the Ref 50 is usually found in like new condition for $1000.
    For an extra $1200, they will throw in a 125.7 amp. Outstanding, get a 6 year old pre-pro for $400, then drop only $1000 - $2200 more to further upgrade your system.
    tonyb Posts: 33,072
    edited June 2007
    The pre is nice,but I would be looking up the chain to a ref 30 or 50.I have seen the ref 307 avr go for under a grand on the gon.
