Will I need a Sub?
If I install 5 LC80I's in ceiling for surround sound, will these produce enough bass for watching movies and listening to low music.
Post edited by interj on
If you are going to be running a 5.1 using in wall speakers you will still need a sub.
Polk offers some in floor subs if you are looking to do a total in wall system.Television: Mitsubishi WD-57732
Front R/L: Polkaudio RTiA7
Center: Polkaudio CSiA4
Rear R/L: Polkaudio FXiA4
Subwoofer: Polkaudio DSW600
A/V Reciever: Denon 2808
DVD/SACD: Sony Playstation 3 -
Yeah, but the $500 sub requires a $700 Amp. I can't swing that!
yes, very much so.engtaz
So then since cost does matter,
Would you recommend going with the RC line and a powered sub over the LC line and no sub. -
Velodyne makes some pretty good, reasonably priced subs. Size and power matters to your room size and personal bass prefrences.
I would recomend the PSW1000...
because it goes to 11
What does,
it goes to 11 mean? -
The volume control on the front goes to 11
For the "goes to 11" refrence, you need to watch the Spinal Tap move.Television: Mitsubishi WD-57732
You definitely need a sub for that setup. It's going to sound very thin without one. No offense to Polk (I have loved the many polk speakers I have owned), but I don't think they offer the best performance/dollar ratio out there in the sub department. Try to fit an in room sub into your decor of you can (SVS, Velodyne, Hsu). If not, I heard a Boston Acoustics in wall/floor sub that I liked, I think it was called the sub 10f. You would still need an amp for that one...could probably pick one up cheaply on audiogon.Monitor Audio GR 60, GR10, GRLCR
Velodyne HGS18
Emotiva MMC-1
Parasound Model 5250
Denon DVD-3800
Pioneer pdp-5070
Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!) -
So will the RC's with a decent sub create good system for HT?
Get the LC's and get an SVS sb12 sub ($699). It is small and hits pretty hard for a little box. Bite the bullet if you have to to get a bangin system that will last you a very long time. SVS also makes a couple less expensive sub's but are a little bigger than the sb12. Check out there website.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
A sub bass is almost standardization in many professional cinemas from Dolby SR installations to SR-D so yes a subwoofer should be used. The more subs you install the better the lower end will sound at its best. But please remember a sub bass speaker should only accompany the sound system not overwhelm it.
Need sub, it will cover the lower Freq. better then your speakers.engtaz
