rotel issue
opus
opus Posts: 1,252
edited June 2007 in Electronics
Lets see if i can get this to make sense. I recently tore apart the rig to install new cables. Afterr I got it back together my right channel is not working. Also my BFD is only showing the left channel working.
So here is what I did.
Checked my setup on the Rotel (i think it is right)
Swapped cables to see if i have a bad one (doesn't appear to be the case)
One curious note, when I undo the left channel IC I lose all sound, ok, because the right channel isn't working. But when I swap channels, for example when I run from rotel left to amp right it still plays on the left speaker and the bfd still shows only left channel.
I did end up with an extra cable or two when I got it all put back together :o but I think I have all my hookups correct.
Any thoughts.......................kevin
ps I also installed my new cdp at the same time.
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited June 2007
    opus wrote: »
    One curious note, when I undo the left channel IC I lose all sound, right, because the right channel isn't working. But when I swap channels, for example when I run from rotel left to amp right it still plays on the left speaker and the bfd still shows only left channel.
    Pictures? Really....
    "when I run from rotel left to amp right it still plays on the left speaker"<----this would not seem possible if the speakers are connected properly. Rotel pre left out to amp right input out to left speaker? Only if the amp outputs are backwards or something internal is wrong. I've been moving speakers all day...maybe I need to sleep on it.
  • opus
    opus Posts: 1,252
    edited June 2007
    ya, my point exactly.
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • opus
    opus Posts: 1,252
    edited June 2007
    The fact that I am not getting the output at the speaker or the BFD leads me to thinking that I have a Pre amp problem. Am I wrong?
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • McLoki
    McLoki Posts: 5,231
    edited June 2007
    Ok....
    BFD - you should only have one channel working (unless you are running 2 subs) so that should be ok. Do verify that the sub is plugged into the channel that is lit up though. (the lights inidcate filters are set, not that signal is present)
    Rotel - assuming no setup changes (i.e. you did not lose any memory settings when you tore apart the gear):
    1. Disconnect all inputs and outputs from your rotel.
    2. Plug all your preouts into your amps (and speakers into your amps if neccesary).
    3. Run through the test tones built into the Rotel verify that all channels are playing. (if not, swap a known working channel for a dead one and see if the problem moves with the cable or stays on the same channel)
    4. Plug in your DVD player and put in a video essentials disk - run through the same test with the test tones.
    5. Plug in the rest of your inputs one at a time and test the channels after each one is plugged in.
    Report results and let us know what happens...
    Good Luck,
    Michael
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2007
    opus wrote: »
    I recently tore apart the rig to install new cables. <DING>
    After I got it back together my right channel is not working. <DING>
    Checked my setup on the Rotel (i think it is right) <DING>
    Swapped cables to see if i have a bad one (doesn't appear to be the case) <PATTERN>
    My thoughts are that you probably answered all your own questions, in your own post. Kevin, seriously man.....
    The easiest way to troubleshoot audio problems....simplify.
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Too many leftovers and changes. Slow down and recheck the Rotel (leftover items and not working is definitely a clue)
    engtaz
  • NeilGabriel
    edited June 2007
    BFD? I always thought that was "big effing deal."
  • McLoki
    McLoki Posts: 5,231
    edited June 2007
    Nope - it is Behringer Feedback Destroyer A 12-band stereo Parametric eq used to tame bass peaks in a home theater setup. They are cheap and work great. (I use one as well)
    Michael
  • opus
    opus Posts: 1,252
    edited June 2007
    dorokusai wrote: »
    Mild beating accepted.:o
    I will work my way through it, but sometimes it nice to ask just in case I am missing something simple or if someone else has had this happen.
    Now I just have to squeeze my fat **** behind the entertainment center:cool:
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • McLoki
    McLoki Posts: 5,231
    edited June 2007
    Opus - on the way to Church, but will give you a call when I get back. I am sure it is just a configuration issue. (if not, I know where you can get a nice NAD cheap... :) )
    Michael
  • dorokusai
    edited June 2007
    Kevin - I'd bet its something pretty easy, you'll figure it out.
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited June 2007
    I hate to say this, but sometimes my Sunfire would get quirky....I would just reset it....Then re-calibrate it...My roommates used to do some silly **** to my processor while I was out, I became a pro at pressing that little button...
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited June 2007
    Pics. Do you by some chance have a left, and right connection going to a pair of left inputs? Is there some type of mono/bridged button/switch on one of your components that may have gotten bumped. Redoing wiring and having wires left over usually is not good, every time I do it I need more:confused::confused::confused: . Any how good luck, and get us some pics if you can
    Later,
    dude
  • MikeC78
    MikeC78 Posts: 2,315
    edited June 2007
    Kevin,
    By any chance did you bump a balanced/unbalanced switch on the amp??
    Mike
  • NeilGabriel
    edited June 2007
    opus wrote: »
    Boy, do I know that issue! At least my knees sound worse than the audio system!
  • opus
    opus Posts: 1,252
    edited June 2007
    Yea I got it. Simple is as simple does.
    It would appear that I Have a bad kimber PBJ. Works sometimes and not others. I thought I had taken that into account but I have so many of those damn blue and red wires back behind there that I got them mixed up:mad: .
    Good news. At least I don't have a bad preamp. Although I'm afraid I got a few stupid points added to my column:(
    thanks for the help. I can now demo my new Azur 640
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Congrats
    engtaz
