Right SDA 1C problem
Ron Temple
The day my HK died, I heard a pop...since my right speaker is about 6.5 dbs down...have swapped the CRS+s to the front and they are within a db and a 1/2, so I figure it's either a tweeter or the poly. Steve, suggested I swap in the SL2000s from the CRS+s to see...he gave me instructions, thanks. I sent him a question via PM, but it occurs that it might be faster here. There are 8 screws on each tweet...Steve said remove 4...which 4...inner or outer?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
Post edited by Ron Temple on
outerDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Danka...:)
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
hang on to the gaskets,,good luckJC approves....he told me so. (F-1 nut)
Do they tend to slip???:eek:
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Swapping out the tweets (both of them) fixed the problem, but I am hearing some roughness. I'm wondering if something on the crossover is causing this. Guess I better open her up and check the wiring. Funny I put the replaced SL2000s back in the CRS+s...during auto-setup they sounded fine...watched a move tonight, but didn't pay attention to the surrounds
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Usually the tweeters or polyswitch give out before the crossovers. The Denon may just make it more noticeable.
I've been crying the blues about the Denon...guess now I have to start listening again and give it a chance. There was a noticeable improvement...doh
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Get the RDO'sAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Very :cool:
Your gonna love themAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
This morning I started in 2 channel...sounded off...turned off the system...turned on...ok, but I heard fuzzy mids on the right...thought about swapping drivers, but got suspicious so re-calibrated...down 6 dbs on the right again. Ok, started getting suspicious of the Carver cuz the tweets I put back in the CRS+ sound fine. Took the Carver out, re-caled and lo and behold, I'm back. I'm going to watch this rig now for awhile, but I think the amp's going back to Seattle.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I've called and emailed CCR, so it's going back to get worked on after my HK gets back. I've been playing around with the Denon driving the 1Cs and it's much better than I originally thought (once I rebalanced the system). It's capable of 135wpc @ 6ohms which is plenty to drive these guys.
Today I A/B'd the Denon against the Audiosource Amp/One which is very clean with nice warm detail. The Denon held it's own, maybe a bit more pop, edgier on the highs, taller and wider soundstage. I elected to put the Audiosource back on the fronts however...piano sounded better, warmer vocals and perhaps a touch more 3dimensionality (is that a word). The Denon doesn't play as nice with the SL2000s, but it was very close. I went back and forth at least 20 times and eventually decided I liked the warmer Audiosource sound a little more. My disappointment in the Denon receiver is no more. It's a nice piece...if it had a bit more control of the highs I'd probably keep it.
Luxman is coming over tonight...so we'll see about this one.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Hopefully this is...
Looks like the Adcom 555, black, no gain controls, 200wpc @ 8 ohm, 300 @ 4 ohms. First thing I noticed was the bass response. Listening to "Cafe Blue", I needed to turn the subs off which I did with the Carver, but this is another order of magnitude. Extremely strong bass response...the midrange seems pronounced with a huge soundstage at least 4' outside the speakers, tall and detailed, but maybe bulging a bit (don't know how to describe it). I think it masks some of the midrange detail I noticed with the Carver, maybe it's the midbass. Highs are warm and crisp, vocals very smooth. All in all, a very nice piece that makes the SDAs shine.
If CCR ever gets back to me...I'll get the Carver fixed and can do an A/B. Both amps have guts, but the Luxman delivers the bass while the Carver has more midrange detail, highs are about the same (that's what my memory tells me anyway) Both the Audiosource and the Denon alone, can't compete with the sheer power and presentation of this amp. Must weigh somewhere around 65 - 75lbs.
The gremlins are gone now...system sounds wonderful again
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Call Rita at Sunfire and talk to her direct. She's told me SHE even has a hard time getting in touch with Mylinda sometimes! I have her direct number if you don't already have it. Just send me a PM.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Older Luxman and Nakamichi were some of the best Japanese gear around at the time, even rivaled many "American" made pieces. No surprise there Ron.
Have fun
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
My friend dropped the manual by last night. It seems this amp is not from the "hifi" heyday prior to Alpine buying them, probably early 90's, but it's still a nice amp...they stole the "tubelike" marketing hype from Carver...it's in the manual . Definitely has some grunt.
200 @ 8
400 @ 4
700 @ 2
1000 bridged
3dbs headroom
65000u capacitance
THD .03%
Slew rate 20/uSec
Damping factor - 130
Peak - 150 amps
52lbs (seems heavier)
12 massive transistors
The rest I don't understand...it's nice to have folks drop stuff off and help a brotha out when his **** breaksdown
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
