Using sound meter to setup sub????
engtaz
engtaz Posts: 7,672
How do you adjust the settings on the sub and AVR for the sub db level? I was able to setup the speakers with a sound meter but not the sub. The sub adjust would be too loud to match the db of the speakers. I don't think I can use the sound meter but I have it adjusted by ear. What is the general method of setting up the volume of the subs.
engtaz
Post edited by engtaz on
  • McLoki
    McLoki Posts: 5,231
    edited May 2007
    I set all channels to the same level (the sub I approximate since it jumps by about 5 db during the test tones). Then I pick music I am familiar with and adjust the sub by ear from there to what sounds right for me. (usually ending up a few DB hot on the sub)
    Michael
  • Schwingding
    Schwingding Posts: 363
    edited May 2007
    Generally - folks set the gain on the sub to about 1/4-1/3 of max, then use the AVR setup routine's pink noise to cycle through all of the channels, using the AVR's level controls to achieve the same decibel level on all speakers, including the sub. Some tweaking for personal preference generally occurs thereafter. People tend to run the subs a few dbs hot.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • THX 3417
    THX 3417 Posts: 219
    edited May 2007
    I’d get a friend who is really obsessed with matter to deal with it because one LFE.1 is a very dicey matter and very unpredictable, as well you really need the level tuned down on it just so it becomes noticeable, not where it becomes overwhelming, thus drowning out the rest of the bass signals from the rest of sound system that is just noise and not artful sound reproduction of the artists intention.
  • scottdwagner
    scottdwagner Posts: 106
    edited June 2007
    Monitor Audio GR 60, GR10, GRLCR
    Velodyne HGS18
    Emotiva MMC-1
    Parasound Model 5250
    Denon DVD-3800
    Pioneer pdp-5070
    Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
