Using sound meter to setup sub????
engtaz
How do you adjust the settings on the sub and AVR for the sub db level? I was able to setup the speakers with a sound meter but not the sub. The sub adjust would be too loud to match the db of the speakers. I don't think I can use the sound meter but I have it adjusted by ear. What is the general method of setting up the volume of the subs.
engtaz
Post edited by engtaz on
I set all channels to the same level (the sub I approximate since it jumps by about 5 db during the test tones). Then I pick music I am familiar with and adjust the sub by ear from there to what sounds right for me. (usually ending up a few DB hot on the sub)
Generally - folks set the gain on the sub to about 1/4-1/3 of max, then use the AVR setup routine's pink noise to cycle through all of the channels, using the AVR's level controls to achieve the same decibel level on all speakers, including the sub. Some tweaking for personal preference generally occurs thereafter. People tend to run the subs a few dbs hot.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
Id get a friend who is really obsessed with matter to deal with it because one LFE.1 is a very dicey matter and very unpredictable, as well you really need the level tuned down on it just so it becomes noticeable, not where it becomes overwhelming, thus drowning out the rest of the bass signals from the rest of sound system that is just noise and not artful sound reproduction of the artists intention.
Monitor Audio GR 60, GR10, GRLCR
Velodyne HGS18
Emotiva MMC-1
Parasound Model 5250
Denon DVD-3800
Pioneer pdp-5070
Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
