humming from speakers
JimBRICK
Hey gys I have a question for you.
I got this Nad reciever and I'm getting a HUM from my speakers when I'm watching the satilite. The problem is that the hum only comes on certain channels. Sounds weird I know but if I'm on say the space channel its ok, I turn to regular cable and get the hum.
Dvd and audio no hum.
think it could be my satilite receiver?
thanks for your help
Jim
Jim
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
You might have a ground loop problem. A ground loop isolator, isolation transformer, or power conditioner may help.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
That was my first thought but I was under the impression that a ground loop would be constant, not with specific channels as Jim describes.
I think it depends on the quality of the signal the station(s) are broadcasting...I get it on some stations with my DirecTV receiver too...Most of the problems I have are programs like the local news...Sometimes CNN gives me a nasty buzz as well...
They hum when they don't know the words.
It could be a ground issue.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
So the winner of this thread is SkyNut. I decided to take apart my whole system and move it to the otehr side of the room and what do you know the humming is gone. The accoustics in the room are better now too. Much happier now2 CHANNEL
Under construction -
Sweet, now teach them the words.
Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
