Comcast HDMI woes( Washington State)
sabotg
I'm sure something about this has been posted before, but just in case anyone's struggling with the same issue, I figured I'd post what I found out. I have a Pioneer Elite receiver with HDMI capability and I wanted to run my Comcast DVR box through my receiver as my TV only has one HDMI input. (Adding an XBox elite soon and want to run that through the elite also) Anyway when I ran the cable box through the receiver I got an error message stating that the Comcast DVR is not HDCP compatible use component inputs and the screen turned green. After a lot of research and contacting Comcast it appears that the Motorola DVR I have thinks my receiver is some kind of HDMI repeater and shuts down the cable box signal.
I determined that my Comcast DVR has firmware revision 12.31 and the fix for this issue is apparently available in firmware version 12.35.(some parts of East Coast are running Firmware 16.35) Comcast has informed me that they are aware of the issue and will be pushing a firmware fix that should correct the issue sometime between June -September:mad:
Until then I
l have to use component for one of my sources and wait for the fix. Just thought I'd clue everyone in in case someone else is having the same problem.
Until then I
Post edited by sabotg on
You have Comcast, enough said.
I also have pioneer elite avr with hdmi connect,here in Bay Area we just recieved new motorola 3416 hd-dvr box from comcast.I just finished hooking up system using hdmi connections and there is alot less mass of cables to use.Audio /video quality seems pretty good,still playing with it.Dealing with comcast is rough,but that is the only cable co.here.Comcast already has these boxes out there so they should be able to provide you this feature asap.
i think some of the Elites also have a problem with HDMI being too dark and some sort of LFE issue..
There is a firmware available to fix some issues with 72-74 models and the newer 80x series Elite receivers...
so keep that in mind as wellPioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub -
Bill Ayotte wrote: »You have Comcast, enough said.
OUCH ! -
I ran into the exact same problem a year ago. I jsut use composite to my TV from the DVR (really doesnt matter since its 1080i anyways). IT keeps my 2 Sony HDMI ports free for the PS3 and the HTPC.Testing
Testing
Testing
