Bi-amp question
Neskahi
Last night I bi-amped my 2.3's and now have a lot of bass [boom] that was not
present before. The tight bass[and I mean tight] that I had before is gone. I believe everything is wired correctly and I did disconnect the jumper wire[at the terminals] on the 2.3's. One amp feed's the highs and the other the lows.
I'm using two Pioneer M-91 amps and a C-91 control amp. I would like to try
the mono block set up but not sure how to bridge the amps.
Is it as simple as placing the power amps in mono mode and using one amp for each channel or is there another method. Please have patience with what must
seem like an elementary question to many but I don't want to fry anything.
Thanks.
Thanks.
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
Also, the interconnect cable is in place.SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
Which amp we're you using when you were using one amp? Maybe the "low" amp has a problem. Re-install the jumper and use one amp at a time in your original "tight" configuration just to make sure each amp is doing the job properly. If all works normally recheck your connections, and try bi-amping again. ABOVE ALL, don't forget to remove the jumper when bi-amping or you will fry one or both amps and possibly your speakers as well.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
How do you have them hooked up?does the M91 have level controls? by chance maybe the level controls on the one driving the upper range are turned down causing the frequency imbalance.Testing
Testing
Testing -
It has level controls and they are set the same, but they have no effect when I adjust them. I'm going switch amps and experiment like joe suggest and report back. I did test each amp seperately on a set of Snell C/V's and all sounded well.
The only other test I know how perform to check the amp's condition is a simple dc offset measurement with a DMM.
Those readings were ok.
I have them hooked up like Polk's diagram shown
in the owners manual for 2.3's,[bi-amping].SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
The tight bass was from an M-'90' I used before bi-amping.SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
Thanks.
Sounds like something is out of phase! -
