SDA 1C crossover question
george daniel
george daniel Posts: 12,096
edited May 2007 in Vintage Speakers
I've going to replace the inductors, if I understand the schematic, the inductor at the upper left of the pic is the 1.25 mHz. Can someone tell me if that is correct,as I cannot find an identification. Thanks in advance--george
Post edited by george daniel on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    The top left is a 1.25mH
    The bottom Left is a 2.5mH
    Ben
  • I-SIG
    I-SIG Posts: 2,243
    edited May 2007
    Most folks say not replace those because apparently there is a lot more to inductors than the Henrys.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • george daniel
    edited May 2007
    thanks,, just wanted to double check,,now if my diagnostic skills are on, this should fix the problem. Got these (1C's) off e-pay for 249.00,very good condition. Upon listeming to them the left side seemed lacking in the mids,,upon removing the passice ,the inductor was laying in the bottom of the cabinet,I resoldered, but the problem still persists,,hopefully this will be the end of this thread,,we'll know in a little while. :)
    heiney9 Posts: 25,421
    edited May 2007
    At Chicago PF I ended up leaving with Normanality's SDA 1C's. It's my understanding a former member (Anonymouse-haven't seen him around in awhile) upgraded the x-overs with Sonic Caps, and Norm and Rich (SCompRacer) added Vampire connectors and a more user friendly IC cable with a bannana plug on each end as well as the RD0 tweets. No mention of replacing any inductors.
    I was tweaking last night and have them 11 inches from the back wall and almost 6 feet apart. Initially I wasn't getting that euphoric SDA effect so I moved each speaker 3" closer to each other (total of 6") and WOW that really made a difference.
    I guess my point is keep looking for the issue, I'm sure fixing the inductor helped. :D
  • george daniel
    edited May 2007
    heiney9 wrote: »
    I have already replaced all the caps with sonicaps,mills resistors, inductors,,,now I'm struggling with no tweeter output after the inductor change,,hell,,, things have got to improve,I've never had this much trouble with crossovers before,when I get home today,I'll check them out. :o:(
    edited May 2007
    I feel your pain. One of the BIG pluses to getting Norm's SDA's were the fact that someone else (competent) had already done all the upgrades. :D
    Good luck, I'm sure you'll sort it out. :)
    SCompRacer Posts: 9,089
    edited May 2007
    Brock, anonymouse performed all the mods to the 1C's you got from Norm. All I did was make the IC a little longer. I am sorry for the confusion. I was running on empty Saturday.
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    good luck george. Are those the one's you robbed from Orlando. LOL
    engtaz
  • george daniel
    edited May 2007
    engtaz wrote: »
    yep,, and I'm almost ready to throw in the towel if my efforts this afternoon do not yield the desired results.
    edited May 2007
    I'm pretty sure a towel (wet or dry) won't fix your problem. :p:p
    F1nut Posts: 51,700
    edited May 2007
    Did you remove the polyswitch. If so, you need to replace it with a jumper.
    Also, check the tweeter and driver output connectors. Both have 4 pins and can be easily swapped by mistake.
  • george daniel
    edited May 2007
    Jesse,I had replaced the polyswitches with jumpers,I wiggled the jumper,,and the tweets started working,so I resoldered it,,,problem solved,,next I replaced the inductors (as one was laying in the bottom of the cabinet upon arrival),problem solved. They are playing right now,so I'll give em a few hours before I button them up. I'll post pics later.I won't even begin to tell ya'll what went through my mind last night,as I was extremely frustrated(it's covered in another thread).Bottom line, caps replaced with sonicaps,mills resistors,inductors from madisound,binding posts and SDA cable connection are Vampire BP-hex, I think I'll take up go-kart racing as a new hobby.:)
    This is my LAST set of 1C's,,I can assure you of that. :D
