What does 6 channel input do?
gools
gools Posts: 18
edited May 2007 in Electronics
I searched it and came up with having something to do with a dvd player hook up I think. (The abreviations used on this forum for features has me lost). I have this feature on my new Amp and don't know if I need to use it
Harmon/Kardon AVR245. Fronts- Monitor 60'2. Centre- CS2. Rears- R15's, Sub- PSW202
Post edited by gools on
  • dragon1952
    dragon1952 Posts: 4,907
    edited May 2007
    I believe it's for sources that have SACD or DVD-A capability. They will have identical outputs on the back. It's so the multi-channel signals are sent to the correct amp channel.
    tonyb Posts: 33,068
    edited May 2007
    Or if you want to use the d/a converter in your dvd player instead of the one in your avr,when watching movies.
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2007
    Welcome to the Club Polk Forums gool!
    The 6 inputs are analog imputs. The hi rez multi channel units for SACD and DVD-A require analog inuts as they only ouput in analog. If you don't plan to use these formats, you can use the optical or coax digital inputs.
    Good luck and Welcome!
    Carl
  • gools
    gools Posts: 18
    edited May 2007
    Thanks guys. I'm using optical for my dvd, so I guess I'll just forget I have that feature.
