What does 6 channel input do?
gools
I searched it and came up with having something to do with a dvd player hook up I think. (The abreviations used on this forum for features has me lost). I have this feature on my new Amp and don't know if I need to use it
Harmon/Kardon AVR245. Fronts- Monitor 60'2. Centre- CS2. Rears- R15's, Sub- PSW202
I believe it's for sources that have SACD or DVD-A capability. They will have identical outputs on the back. It's so the multi-channel signals are sent to the correct amp channel.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Or if you want to use the d/a converter in your dvd player instead of the one in your avr,when watching movies.HT SYSTEM-
lsi 9's -
Welcome to the Club Polk Forums gool!
The 6 inputs are analog imputs. The hi rez multi channel units for SACD and DVD-A require analog inuts as they only ouput in analog. If you don't plan to use these formats, you can use the optical or coax digital inputs.
Good luck and Welcome!Carl -
Thanks guys. I'm using optical for my dvd, so I guess I'll just forget I have that feature.Harmon/Kardon AVR245. Fronts- Monitor 60'2. Centre- CS2. Rears- R15's, Sub- PSW202
