Bi-amp question
Neskahi
Neskahi Posts: 297
Last night I bi-amped my 2.3's and now have a lot of bass [boom] that was not
present before. The tight bass[and I mean tight] that I had before is gone. I believe everything is wired correctly and I did disconnect the jumper wire[at the terminals] on the 2.3's. One amp feed's the highs and the other the lows.
I'm using two Pioneer M-91 amps and a C-91 control amp. I would like to try
the mono block set up but not sure how to bridge the amps.
Is it as simple as placing the power amps in mono mode and using one amp for each channel or is there another method. Please have patience with what must
seem like an elementary question to many but I don't want to fry anything.
Thanks.
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
  • Neskahi
    Neskahi Posts: 297
    edited May 2007
    Also, the interconnect cable is in place.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • joeparaski
    joeparaski Posts: 1,865
    edited May 2007
    Which amp we're you using when you were using one amp? Maybe the "low" amp has a problem. Re-install the jumper and use one amp at a time in your original "tight" configuration just to make sure each amp is doing the job properly. If all works normally recheck your connections, and try bi-amping again. ABOVE ALL, don't forget to remove the jumper when bi-amping or you will fry one or both amps and possibly your speakers as well.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Systems
    Systems Posts: 14,873
    edited May 2007
    How do you have them hooked up?does the M91 have level controls? by chance maybe the level controls on the one driving the upper range are turned down causing the frequency imbalance.
    Testing
    Testing
    Testing
  • Neskahi
    Neskahi Posts: 297
    edited May 2007
    It has level controls and they are set the same, but they have no effect when I adjust them. I'm going switch amps and experiment like joe suggest and report back. I did test each amp seperately on a set of Snell C/V's and all sounded well.
    The only other test I know how perform to check the amp's condition is a simple dc offset measurement with a DMM.
    Those readings were ok.
    I have them hooked up like Polk's diagram shown
    in the owners manual for 2.3's,[bi-amping].
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • Neskahi
    Neskahi Posts: 297
    edited May 2007
    The tight bass was from an M-'90' I used before bi-amping.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    Neskahi wrote: »
    Thanks.
    Sounds like something is out of phase!
  • kocci
    kocci Posts: 2
    edited May 2007
