Question on Flat Panels
MacLeod
MacLeod Posts: 14,358
edited May 2007 in Electronics
My uncle was out shopping for a flat panel TV and the salesman recommended against them and told him that with plasmas and LCDs there was some thingamajiggy that you had to replace every couple years for routine maintenance which cost about $300!
I have never heard of this and was under the assumption that LCDs and plasmas required no maintenance and would last upwards of 20 years!
Is this salesman the usual dolt you find in these stores or have I been missing something?
  • JimBRICK
    JimBRICK Posts: 1,543
    edited May 2007
    MacLeod wrote: »
    Its lcd projection and dlp that you need to replace the bulbs in. they have a lifetime of 5-6000 hours. Lcd and plasma can have a 60000 hour lamplife. so really it all depends on how much tv you watch. When I sell lcd projos and dlp I make sure the customer knows they will have to replace the bulb. Dont want an angry cust thinking he got screwed in 5 years
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Systems
    Systems Posts: 14,872
    edited May 2007
    Like Jim said most current flat panel LCD's and Plasma's are claiming 60,000 hour lifespan.
    Testing
    Testing
    Testing
  • MacLeod
    edited May 2007
    Good. Cause I told my uncle the guy was wrong but as with most older relatives, they always think Im wrong! :D
    So the LCD and Plasma flat panels are good to go for 10+ years but the DLP and LCD projectors need the 5 year replacement.
    Thanks guys! I appreciate any chance I get to rub in his face that I was right! LOL :p
    billbillw Posts: 8,370
    edited May 2007
    Mac,
    Just so you are clear, any of the rear projection type (LCD/DLP/LCoS/SXRD) have a single projector bulb that needs replacing. They say 4000 hours, but many folks have had to replace these in only a year or two. Average cost is about $300.
    On the flat panels, LCDs have built in back light that is rated at 60000 hours average. This will be less if the viewer is always watching at the brighter settings, but it still should be 15 years or longer.
    Plasmas are different. Technically, they don't have a back light. Each pixel is its own light source. The life span of a plasma is determined on how fast the plasma gas leaks out of the panel glass. They gradually loose brightness over the course of many years as the gas leaks out. This process is accelerated by high altitudes, and of course by having the TV adjusted to its brightest settings. Early plasmas were found to be significantly less bright after several years, but the newest ones are rated for much longer. If adjusted to proper settings (not brightest) and at normal altitudes, you should get 15+ years out of a plasma now, just about like an LCD.
  • danger boy
    danger boy Posts: 15,722
    edited May 2007
    rarely do people keep their TV's of any kind for 10 yrs anymore..
    If i were in the market for a flat panel display.. i'd expect it to last a good 4 or 5 yrs tops.. imagine someone holding onto their plasma tv for 20 yrs? LOL by then.. we won't even have displays anymore.. it'll all be holographic images.. :)
    PolkFest 2012, who's going>?
  • ilikesound
    ilikesound Posts: 355
    edited May 2007
    we'll all probably be walking around with virtual-boys on our heads in 15 years.
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
