Suggestions on taming the wire RATS nest
engtaz
I am looking for ideas people have on getting control of all the wiring.
engtaz
engtaz
engtaz
Post edited by engtaz on
Are you speaking "functionality" (is that word?) or in relation to looks (like with an open backed equipment rack)? I don't know what your setup looks like so here goes anyway.
If it's for looks, I've seen flexiable tubing (black) with a lengthwise cut on it so wires can "snap" into it. You could make all your wires long enough to go from the floor up to each level and use this tubing to hide them in (branching out at each level for equipment hook up). I'd cut notches at each level for the branch outs.
If you're speaking of "functionality" then, if possible, cut down the excess wire you have at your components. If you have, let's say, 6" more wire than was needed to hook up all speakers on a 5.1 set up then you have 36" (3' worth) of extra wire that really wasn't needed. More wire equals bigger rat's nest.
You could use those Velcro wire running strips (fuzz on one side and "hooks" on the other side). As the wires leave your equipment to go elsewhere you could use these strips to group them together. One group could be your speaker wires, another could be for the wires going from your preouts to an amp, etc. They're kind of expensive but depending on the length you might need, they cut easily with a pair of sissors so you could make two usable pieces out of one strip.Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
Looks. good ideasengtaz
How about some techflex expandable tubing, for bundling. It comes in several different sizes.
Clean up the ends with shrink wrap.
http://www.techflex.com/prod_PTN.asp -
To clean up the wiring behind my TV stand, I went with the "budget" approach (a.k.a. the poor mans approach). I used black zip ties that I had left over from cleaning up the wiring in my computer to bundle the speaker wires together. I also used the same black zip ties to bundle the power cords together.
So, from the AVR the speaker wires are just bundled together and look like one big wire when viewed from the front. The same is true for the power wire. For excess cables (coax for the cable TV, optical from the DVD player to the AVR, etc.) I just used extra black electrical tape to tape the excess length to the back of the TV. Again, this is just so that they are out of sight when you are viewing the TV from the front.
It's not the cleanest, nor the prettiest, but it suffices for my purposes and I was able to reuse existing materials that I already had laying around.
Let us know what you end up going with...I'll be interested to see how it works out for you.My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
Zip ties done up so that the cables all fit and run in smooth loops together. I do this on machine installs all the time space the ties equally and it looks very uniform. I run all power cords together then speaker cables then rca and digital lines. The help support each other and lower strain on the equipment as a whole.......:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
The reason I mentioned the velcro strips instead of Tywraps is because if he changes his wiring configuration for any idea he has to be real careful not to nick or cut into one of the cables in his bundle(s) to remove them. Also, they're not reusable.Deadof_knight wrote: »Zip ties done up so that the cables all fit and run in smooth loops together. I do this on machine installs all the time space the ties equally and it looks very uniform. I run all power cords together then speaker cables then rca and digital lines. The help support each other and lower strain on the equipment as a whole.......Be gentle, I'm new to all this...
Oh well that a good point the velcro strap they have out for computer cables I think even walmart has them now:cool: " He who dies with the most equipment wins Right ? "
I had my wife pick up some flexible tubing from hardware store...like vacuum tube or maybe washer drain tube....however the tubes were too narrow to run much through them as the plugs would not go through after first couple wires...so I need to cut the slits in them and then try snapping them on. Yet one more reason just to get a good boombox! My bluejean cables came with a nice velcro stip around them....I put it somwhere.
I use split tubing, wire loom, zip ties, cable organizers, and cable clips. Makes the job much easier. Also, I try to nail coaxial cable to the wall (since the cable company always forgets to do that) and use shorter cables to eliminate wire tangles. Custom-made cables help a lot with this matter.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
