vintage amp for 2 chan system......
  • JimBRICK
    JimBRICK Posts: 1,543
    edited May 2007
    CDP-2A is the model number of my NAK its a single disk and works great. the person I bought it from didnt have the remote but I got the manual
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2007
    I think all the vintage gear you found is cool and if its local, jump on it. It's great to check out old school gear, have fun.
    Here's a couple pics of a factory fresh Sony:
  • izafar
    izafar Posts: 821
    edited May 2007
    That Sony is looking so yummy...
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • JimBRICK
    edited May 2007
    I have a couple I'mlooking at right now with Doro's being my backup. When I have one in place I'll post the pics here of the ultimate cheap **** 2 channel rig :)
    2 CHANNEL
    Under construction
  • dorokusai
    edited May 2007
    Go local if you have a chance.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2007
    Throw a dog a bone, and it becomes a 'backup'?
    Ouch.
    I just threw that same Sony receiver in the landfill last week, had a wood case and everything. Worked fine, but the tuna string broke, and I didn't feel like restringing it. I did pull the knobs, but that was it.
    Cheers,
    Russ
    heiney9 Posts: 25,577
    edited May 2007
    RuSsMaN wrote: »
    Ouch.
    Cheers,
    Russ
    Doesn't anyone burn useless things anymore :confused::D .
  • JimBRICK
    edited May 2007
    backup cause we both agreed that finding local would be smarter. I love sony though, I know alot of people here hate sony but everything I've ever bought from sony I still have and it still works perfectely. even mybig **** walkman from1982
    2 CHANNEL
    Under construction
  • RuSsMaN
    edited May 2007
    All well and good, the little lady still has her original easy bake oven, perfect working order - but I don't have any light-driven cake mix. Guess who is sans cupcakes tonight? Think I give a **** about that easy bake?
    Cheers,
    Russ
  • JimBRICK
    edited May 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    reason number 4 why not to post after ingesting moonshine
    2 CHANNEL
    Under construction
  • moo
    moo Posts: 1
    edited May 2007
    billbillw wrote: »
    Jim,
    You can also expect that most vintage pieces will need a little work to get them up to full potential. Unless its already been done, they usually need pots and switches cleaned with deoxit. DC Offset and bias should be checked before first use. Tuners almost always need to be cleaned and realigned. In addition, any electrolytic capacitors are probably going to need replacement in a fairly short time. Vintage gear can be lots of fun, but at the same time, its a risk because service manuals can be difficult or impossible to find, and parts availability can often be very limited if there is a problem. Good luck if you go that route.
    Is there any guides available on how to check the DC offset and bias as you have mentioned? Is it just using a multimeter set to DC to measure the output on the speaker terminals?
    Thanks.
