Abnormal B&K Pop - Need Help
Gaara
A little history...
Ok guys need a little help hopefully from someone who has a B&K Reference 50 and from someone with a B&K Reference 50 S2. You also need to have a 7.1 setup.
The Ref 50 was known a while back for having a popping sound that occurred in all the speakers when going through menus, as well as when changing scenes in movies. They fixed it, if I recall correctly by adding a muting circuit, and all was good. This is a different pop.
I wont bore you with the details but my system went through some changes, I went from 7.1 to 5.1 a few times, and changed my speakers from Polk LSis to Gallos all around. I had been using a Outlaw ICBM for bass management but took that out of the system, set my front speakers to large, center to none and my surrounds to small and everything was good...until I went back to 7.1.
I got my Sunfire amp and the first thing I noticed was a very loud popping sound coming only from my back right surround speaker. I did all sorts of testing to figure out what was causing it but narrowed it down the the B&K. I tried doing a system reset which fixed the problem...until I changed the settings.
XxXxX IMPORTANT PART XxXxX
So here is what I need a couple of fellow polkies to do, can you change your settings for me? Nothing big just speaker size, set:
Fronts to Large
Center to None
Surround to Small
Surround Back to Small
Subwoofer Yes THX (S1 only)
THX Ultra 2...doesn't matter
In my system with those settings I get a annoying pop in my back right speaker. It happens when I navigate menus, change scenes in dvds, or change the settings on the b&k.
With Center to anything but none there is no pop.
With fronts to small there is no pop.
With both sets of surrounds set to large there is no pop.
With Subwoofer set to no there is no pop
With Subwoofer set to Ultra there is no pop
I just want to know if this is a unique problem I am having or if it is common place. I also want to know if I upgrade to a S2 (I want PLIIx) if I will have the same issue. I talked to B&K and they have never heard of it, but could take a look if I shipped it in. I have put the ICBM back in to fix the problem, and would rather not be without my system for a few weeks and be out shipping charges to send it back.
If you made it this far thanks for reading, and thanks to anyone who can help me out.
Jared
Fronts to Large
Center to None
Surround to Small
Jared
Why don't you call B&K? I had the "pop" on my before the upgrade to 317 but its been solid since then.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Mark,
I tried calling them and they couldn't figure out why it only popped with very specific settings. They said my only option would be to send it in, which would take a minimum of 2 weeks...assuming they could figure out what the problem is. I would rather not be without my HT for 2 weeks during the summer, as I have been using it 2-3 times a day recently.
I have found a away around the problem, by setting all the speakers to large and using my ICBM to do bass management. I just want to know if this is a isolated incident with my unit, and if I upgrade to a S2 if I will have the same problem.
Jared -
Jared - You know, as I read your response it reminds me of a couple calls to them. They are pretty short when it comes to troubleshooting on the phone and the quick answer is just what you said....send it in.
I seriously doubt that you would have the problem after the upgrade. I was really pleased with the service and my issues were solved.
I'm glad you found a workaround but settle in and take the hit....time to upgrade.
MarkCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I used get a pop when I switch certain surround modes but I haven't noticed it lately. Probably since I've settled in on THX mode and don't ever change it anymore. The reason I remember hearing was that the switch in the AVR was a mechanical switch.
The upgrade took care of the usual pop and mine seems to have a better overall performance. What ever, it was definitely worth the time and effort of sending it back.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
I need a little clarification, which upgrade is everyone talking about? I sent it in to fix the popping sound about 2 years ago and it fixed the problem (Firmware 2.0 upgrade I believe). That pop happened all the time, not to loud, through all speakers. Or is everyone talking about the upgrade from S1 to S2?
This pop only happens when I have the unit set up a very specific way as outlined above, and only happens loudly through my back right speakers. It also sounds different tonally then the popping before.
Thanks.
Jared -
I'm refering to my upgrade in regards to AVR307 to AVR317. I had the audible circuit pop on all changes in regards to soundfields. The upgrade to 317 essentially turned the unit into an AVR507 S1 internally. The upgrade resolved my problem.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yeah thats the upgrade that I got a few years ago. They changed the firmware to 2.0 and did some internal changes...I believe they added a muting circuit. It eliminated the pop coming from all speakers, but this is a different pop.
