ISonic Alarm setting ?? also time setting problem
dreamss
I do use the alarm function of the ISonic but do not wake to easily with the gradule volume increase. Is there a way to turn off this so the volume i set before i go to bed is the same volume I wake up to.
Also
I am haveing a bit of an issue where the time region code keeps coming up and have to hit the enter button to save the setting again.
Also
Post edited by dreamss on
Hi dreamss. Currently, there is no way to have the alarm come on at your desired volume.
When the time region pops up, it means the I-Sonic was most likely subjected to a low voltage from the wall outlet.
Hope that helps.
BrianBrian Knauss
ex-Electrical Engineer for Polk -
Hi ...My Isonic clock seems to run faster than every clock in my house. Where I am moving the Isonic clock back a couple of minutes every week or so.
Has anyone experienced this....and are there any known fixes...
thanks in advance! -
I've had to reset the time/region once so far, always wondered why it happened. Thanks Brian.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Hello,
In all likelihood any I-Sonic that is experiencing a problem keeping correct time has a less than perfect clock timing crystal. Any owner is enclouraged to send their I-Sonic to Polk Audio, 2550 Britannia Blvd., Suite A, San Diego, CA. 92154. We can quickly replace the crystal and get your unit back to you in very short order. Please include a short note giving us your name, address a daytime telephone number and a description of the problem.
Regards, Ken -
Ken to the rescue again and again and again. He is the man.engtaz
