HDTV Advice
sterling bug
Interested in a couple of 42" widescreen rear projection models from Mitsubishi and Toshiba. Would appreciate any advice from you experts out there. Recommendations for other brands are welcomed too.
Post edited by sterling bug on
I've got a 55" 16x9 Mits. and I am very happy with the picture quality, especially HD.
Thanks for the reply. Visited your site, love the setup. How much did your componet rack cost?
Thanks Sterling! I paid around $200 for it at SoundTrack. You can get it at crutchfield also. Here's a link if you're interested.
http://www.crutchfield.com/cgi-bin/S-2HF4eUMoMBQ/ProdView.asp?s=0&c=1&g=109100&I=138RTAG100&o=m&a=0 -
i seccond the mits. if you chave trubble getting the tv to where you want it like into the basement get the 65. it is a 2 piece unit. i have the ws 65819 it is sweet but dont have the hd tunner in it.there is not enough hd programing out there to justify it.
goingganzo, dddaaaammm you are moving on up my man. The 65 incher and now that awesome subwoofer project. And I can understand most of your post now - you go with your BAD self!!;)
