Need more optical audio inputs
OpticalSerenity
I have a Denon AVR-1706, and I'm using both my optical inputs, and one coax digital audio input. Unfortuntately, most of my devices have optical out and not coax.
Anyway, lets say I want to add capability for more optical inputs....such as perhaps a source switcher? I don't have it in my budget just yet to upgrade to a new AVR....
What would you do?
What would you do?
Post edited by OpticalSerenity on
Maybe something like THIS ?Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
These can be "daisy chained" for more outputs, right? Just curious...wingnut4772 wrote: »Maybe something like THIS ?Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
interesting.. i didn't know such a device existed.. and for only $19.99!!PolkFest 2012, who's going>?
But no remote LOLengtaz
I used to use one when I ran out of inputs on my old Onkyo. There is no remote for sure. You just 'dial' it to the correct optical hook up for whatever it is you are doing.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »I used to use one when I ran out of inputs on my old Onkyo. There is no remote for sure. You just 'dial' it to the correct optical hook up for whatever it is you are doing.
LLLLOOOOLLLLengtaz
Well, thanks for the link.
I was hoping to find something with a remote so I can program my Logitech Harmony...
I guess I need to look strongly at a new Denon. -
Anyone know of one that has a remote? I've been searching all over google/fry's/newegg and either I'm blind or its just hard to find. Would it be better to just upgrade AVR? I've found some switches that are $900, so in that case it would be. :-/
The problem with optical is that you either have:
1)A mechanical switch (where a short piece of fiber optic cable is bent to align with a given input) or
2)A decoder, a switch, then a encoder (NOT cheap)
I suppose you could have a motor-driven mechanical one w/ a remote, but I've never seen one.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Oh, perhaps thats why I'm running into the issues I'm having...
Well darn, what a reason to look for a new AVR.
