Help with placement
bernied
bernied Posts: 4
edited May 2007 in Speakers
I'm having an addition built, the top floor being the family room. It measures 30' long by 20' deep and has a cathedral ceiling measuring around 18'. I'm having a "bump out" built to hold the 65" Hitachi which will also have side shelving units. I'll house the electronics on one side and stuff on the other. This is centered on one of the 20' walls which leaves approximately 4.5' feet on each side.
The listening area will basically be to couches running perpindicular to the bump out with two lounge chairs at the end basically making a U shape area.
I've purchased a Pioneer Elite VSX80TXV as the receiver. For speakers I went with the LCIC (inwall center), TC265I (inwall fronts), TC80I (in ceiling surrounds), and two PSW303B subwoofers.
The subwoofers will be placed in the bottom corners of the bump out. The fronts obviously will be on either side of the TV, around 4' high and approximately 8' from each other. I went with the in ceiling TC80Is since I don't have wall space available on either side of the listening area. One side being a stone fireplace the other a large archway into the kitchen. This is where I'm having a bit of a placement problem.
My thought is to have the in ceilings about a foot wider than the fronts. This will be a spacing of approximately 10' - 11' between the two surrounds. The plan is to place them on the ceiling where they will be basically pointing down along the outer perimeter of the listening area.
How does this speaker setup sound? Would appreciate all input.
Thanks,
Bernie
Post edited by bernied on
  • bernied
    bernied Posts: 4
    edited May 2007
    Need to get the wiring up tonight, insulation is happening tomorrow. Can anyone provide input on this speaker placement, I want to get it right the first time.
    Thanks!
    Bernie
  • bernied
    bernied Posts: 4
    edited May 2007
    I still have a few hours before the insullation goes up. All I'll need to run are the surround wires which will only take me 30 minutes or so.
    Still time to provide helpful input, if anyone cares to.
    Bernie
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Somebody with inwall speaker knowledge please help him with ya, na, or input. Nobody likes to second guess their work.
    Thanks,
    engtaz
    engtaz
  • bernied
    bernied Posts: 4
    edited May 2007
    Thanks for all the helpful input. I found this website very informative...NOT!
  • bradm6406
    bradm6406 Posts: 39
    edited May 2007
    Wow, nothing like joining a forum a couple of hours before you're wiring your in-wall and in-ceiling speakers and asking questions about where you should wire them and then leaving in a huff when nobody responds before your very short deadline.
    I haven't been here long but I have found the people on this board to be very helpful and to have lots of information, but online forums generally just don't work that quickly.
    Also, not a lot of people have in-wall or in-ceiling speakers so my guess is that not a lot of people were confident in the advice they would have given you and that may be a large part of the reason you didn't receive a bunch of responses.
    Maybe you could plan a little farther in advance next time and give yourself time to ask questions and get responses.
    Brad
  • Paramount Polk
    Paramount Polk Posts: 38
    edited May 2007
    also, if one forum doesnt seem to respond as quick as you expect, try joining multiple forums... try www.PartsExpress.com someones always looking since everyone looks at the same page. Good Luck!-i have no experience with in/onwall
    Receiver- Onkyo TX-SR304S
    Speakers- Front-Polk Rti4
    Rear- Bose 161
    Center- Bose Cubes
    Subwoofer- composed of
    -PIONEER TS-W251R 10" SUBWOOFER
    -Dayton 1.0 CU FT SUBWOOFER CABINET
    -DAYTON SA240-B 240W Sub Plate Amp
    Desktop
    -AMD Athlon 3000+ 1.8Ghz
    - Geforce 6600
    - 512mb Ram upgrading soon...
    - 80 Gig HD 160 Gig Slave HD
    - ECS Nforce-A939 Motherboard
