Looking under the hood
1…1011131516…43
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2007
    billbillw wrote:
    Wes,
    That's pretty cool to see the two amps side by side (well almost). I can see subtle differences on the input board and the power supply boards are bigger. Those white ceramic things are resistors and I have no idea why there are so many. These amps are more similar than they are different, that's for sure.
    Definitely lots of similarities.
    I suppose John Curl just smoothed out the edges of an otherwise very good design to make a great one.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • louthewiz
    louthewiz Posts: 581
    edited March 2007
    :D Here is my little amp that has 150 wpc driving a pair of rt400 vintage polks!!:D
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • dorokusai
    dorokusai Posts: 25,661
    edited March 2007
    Correct, the Mark II in relation to any HCA series from Parasound indicates John Curl work. That was when he started working/consulting for Parasound.
  • Systems
    Systems Posts: 14,872
    edited March 2007
    They are the emitter resistors for the output transistors.Each output transistor will have one.
    Testing
    Testing
    Testing
    billbillw Posts: 8,371
    edited March 2007
    Not exactly. The emitter resistors are located on each output board. They are grey striped resistors, not the big white ceramics. The emitters can be seen in my closeup of the transformer. On my 2200ii, the big white ceramics are all attached to the power supply boards. I haven't taken the time to look at the schemetic and figure out their purpose yet.
    EDIT: I was wrong about the white ceramic things. I looked at the schematic and then again at my pictures. Those are not resistors at all, they are film caps. All part of the power filtering.
  • Systems
    edited March 2007
    OOOPS my bad,:confused: I was looking at louthewiz amp pic and mistaked it for the parasound.His uses ceramics for the emitter res.
    The ones connected to the filter caps in yours are probably to help discharge the caps after turn off or are used in combo with a small cap to shunt hi frequency noise.
    Testing
    Testing
    Testing
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    I-SIG wrote:
    Y'all,
    Here's the insides of my Parasound HCA-2200.
    Notice the massive stacked torodial trannies and dual sets of caps.
    Everything else seems pretty bread & butter, just on a bigger scale. :D
    Anyone know where I can get some nice metal binding post nuts to replace the crappy plastic ones that are breaking? I'm gonna post this question in another thread since this one is way looooong.
    ETA: Seems like the MkII has almost double the little white, ceramic looking things that are part of the output sections. That and the switches for un/balanced seem to be the only non-cosmetic differences that my untrained eye can see. ***BTW, my 2200 is SDA-safe.***
    Wes
    Wow Wes those pics exude power!!!
    edited March 2007
    I looked back on the schematic for my HCA-2200ii. Those big white "ceramic" looking things in I-SIG's and my amp are film caps, not resistors. That's what happens when you just don't look close at something.
  • speakergeek
    speakergeek Posts: 555
    edited March 2007
    PolknPepsi wrote:
    Man, this is one fascinating thread..........:cool:
    I concur!
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2007
    Parasound HCA-1000 pics coming tonight!
    Wes
  • hearingimpared
    edited April 2007
    I-SIG wrote: »
    Wes
    I can't wait in that I never opened mine up.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2007
    Y'all,
    Here's the happy snaps of the interior and **** of the Parasound HCA-1000A. It's like a mini-single transformer 2200, kinda.
    Wes
  • hearingimpared
    edited April 2007
    I-SIG wrote: »
    Y'all,
    Wes
    Gee what a coincidence, mine looks just like that except for the S/N.
    edited April 2007
    I-SIG wrote: »
    Y'all,
    Wes
    Actually looks just like the inside of an HCA-1500a, but smaller everything. The layout is almost exactly the same.
    See Gator's post here:
    http://www.polkaudio.com/forums/showpost.php?p=532815&postcount=257
  • hearingimpared
    edited April 2007
    billbillw wrote: »
    Well now that I've seen that I want that one instead!
    heiney9 Posts: 25,724
    edited April 2007
    Beefy Class A amplification that I don't own :mad: .
    Pics 1 & 2 Threshold 400A stereo amps
    Pics 3 Threshold One Mono amp.
  • speakergeek
    edited May 2007
    Found this shot of a VSX49TXi Elite online. Pretty decent innards really...
  • speakergeek
    edited May 2007
    louthewiz wrote: »
    That Audiosource amp looks real solid there.
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Here's a few pics of my Marsh A400. It's got the biggest transformer I've seen -- about 6 in. in diameter and about 4 in high. The blue caps are 15,000 uF capacitance each.
    "God grooves with tubes."
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited May 2007
    Early B. wrote: »
    That's purrrrrrrrrrrrrrrrrty...I like the simple look of the faceplate....
    VR3 Posts: 29,763
    edited May 2007
    The biggest transformers Ive seen were in UNC's amp - the Anthems.
    Talk about BEAST.
  • engtaz
    engtaz Posts: 7,677
    edited May 2007
    Nice design in the amp.
    engtaz
  • Systems
    edited May 2007
    Just dug this out of storage today.It as Nelson Pass diy Mosfet design that I built several years ago and no longer use.It is a good sounding unit with the mosfets imparting a tube like quality.I put the transformer in a separate case to avoid induce any AC hum. I guess I better find it a new home instead of letting it collect dust.
    Testing
    Testing
    Testing
  • hearingimpared
    edited May 2007
    GV#27 wrote: »
    Nice looking piece, good work.
  • Systems
    edited May 2007
    Thank you.
    Testing
    Testing
    Testing
  • dorokusai
    edited May 2007
    GV#27 wrote: »
    Real nice DIY stuff GV, thanks for posting it.
  • Systems
    edited May 2007
    Thanks doro.
    Testing
    Testing
    Testing
  • brijenjas
    brijenjas Posts: 311
    edited June 2007
    Got my Emotiva UL combo about 2 weeks ago, but the processor was DOA.
    Here's some pics pf the LPA-1 amplifier.
  • THX 3417
    THX 3417 Posts: 219
    edited June 2007
    With a title heading like this I could hath sworn it was a **** video flick thread.:D
    I guess titles for threads is getting harder and harder to come up with?
    So its about an amplifier and what’s under the bonnet so to speak hay? Well I’d like to get the lid of my Alesis RA300 for a few picture takings?
    Looking at the above post I’m wondering what is the cost of the amplifier unit (LPA-1) looks costly and the best ways or solutions for better home cinema is via active crossover. And seeing there’s six amplifiers onboard the (LPA-1) and yes I know its designed for a 6 channel LCR left and right and centre back surrounds!
    But what is the cost? It would be great if you can install a few of these one for LCR active crossover for the fronts one more for the surround channel arrays including (height surrounds overhead) yeah I bet you haven’t got height surrounds.
    And one more for the sub bass arrays! Its best to use the same amplification for all loudspeakers arrays just like how they do it in the professional THX cinemas!:p
    Don’t bother with active powered sub bass units there a waste of time, use passive cinema 18" types and with a little ingenuity a few DCX2496 you can have a one hell of a home cinema sound system that would surpass your last home cinema sound system.
    mhardy6647 Posts: 35,562
    edited June 2007
    Well, I see your problem... you've got a quarter in there that must've shorted something out! ;-)
