Can you go too big?
mark090852
mark090852 Posts: 1,001
I'm fairly new to all this but have really enjoyed turning our family room into somewhat of a "home theater". We're using Monitor 50s as front speakers, CS1 center, and two RC65i in wall speakers in the rear. I have an SVS SB12-Plus subwoofer (which I upgraded to just 3 months ago from a Polk PSW 100).
Well, I've started to get another case of "upgradeitis". I've been looking at the new SVS 13" subs that are going to be coming out soon. I've got the perfect corner to put the PC13-Ultra in. Even my wife agreed that it wouldn't look "too bad" in this corner. lol. I think I'm going to be listing the SB12-Plus for sale and ordering the PC13.
I realize the larger sub is "overkill" but if I calibrate it properly I'm not aware of any downside to it. Am I correct in this? At some point I may change another room into a dedicated home theater and upgrade the rest of the speakers.
I've learned so much from reading the postings here on this forum the last few months and would appreciate any thoughts any of you would have about this.
Mark
McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers
Post edited by mark090852 on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    I don't think you can go "too big" for a sub. It's not going to hurt your system at all if calibrated correctly.
    The thing I would consider is, "Is you current sub over-worked or not cutting it?" Unless your have a big room, I'm guessing your SB12 Plus is probably is going to through the motions. It's probably not using it's full potential, so why upgrade?
    I think for the money difference between the two subs, that money could be better spent upgrading whatever your weakest link is. Post your system components and ask what others might consider upgrading first. I'm sure you could get a new source, upgraded speakers, or something else with that money that would be of better use of your fundage.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Demiurge
    Demiurge Posts: 10,874
    edited April 2007
    People often confuse good sound with the ability to go loud (these amps go to 11!!).
    That sub isn't overkill unless you crank it to the max. As stated above, proper calibration will make that a great sounding sub for your room.
    I'd say go for it and enjoy!
    So, when are you getting the LSIs? :D;)
  • kalgiers
    kalgiers Posts: 14
    edited April 2007
    The 2 things to look out for when looking @ that I've found are;
    1. While not always the case sometimes larger drives are less articulate and have trouble reproducing upper registers of the frequency spectrum. Simple physics - larger cone surfce the tougher it is to get moving in unison and is harder to start and stop accurately.
    2. Distance from the sub, if you're too close the lower registers will have such a long wave form that it will not fully develop by the time it reaches the listening position.
    Be a little surprised if either of these would come into play here if a 12" already is working well for you.
  • mark090852
    edited April 2007
    Andy, I appreciate what you're saying. But I have this empty corner that is just crying out to be filled with a large cylinder sub. :) The SB12 doesn't quite fit aesthetically with where we have to place it in the room. It's sort of "stuffed" behind the sofa next to a bench and a plant.
    I am VERY impressed with the quality and performance of the SB12 that I have now. I'm certainly not needing to upgrade the sub, it's one of those desires based on passion (I like the way it will look and I like its capabilities) rather than practicality. I think I'm going to delay upgrading any of the other HT components until a decision is made regarding setting everything up in another room. I know the PC13-Ultra will work well with whatever the final decision is and it will perfectly fit in an unused corner in our family room. Actually it will somewhat enhance the aesthetics of the room.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    I would consider my sonosub too big. Its not really the size, but I have my speakers set at 0, and my sub set at -7, and that is plenty of power. If I turn it up all the way particles start falling from my drop ceiling, and I start hearing noises from different things resonating in the room. I am very pleased with its SQ. It is actually very musical, accurate, and tight compared to some other subs I have owned. What I really recommend you asking yourself is do I turn my sub up all the way (without distortion)? One other thing I recommend is maybe getting a second equal sub to balance things out. Some people say bass isn't localized, but I really hear, and feel where it is coming from. I am thinking about building another one. Not for more output, but to balance out the system.
    Ben
  • mark090852
    edited April 2007
    Ben,
    A second equal sub would be nice, but there just isn't an acceptable location in the room to put it. The only place acceptable to my wife would be in one of the corners behind the love seat and a box sub just doesn't look right in that location.
    Mark
  • engtaz
    engtaz Posts: 7,672
    edited April 2007
    Ben is the expert. He tried to blow his ear drums sampling his sonosub. LOL
    engtaz
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited May 2007
    I have one of the original PC-Ultras in our HT rig...it's the about the only piece of gear that I haven't upgraded...and I don't plan to.
    If you want a new Ultra,then by all means,get one...Once you get your head set on something,the desire will not change until you follow through.
    I'm positive there will not be any regrets.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2007
    i would say ask your self if you need more bass if you are botoming out or have realey high thd thn upgrade your sub. if not uprrade your mains/center or your recever or your tv.
    disclamer
    if your are a real bass head then yes upgrade your sub but i would get the dual svs and not just get the new 13 in driver.
    or diy your self a ib setup with at least 4 18 in drivers and 1000 wats
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
    goingganzo wrote: »
    I second that one.
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    No, a large sub gives you a different type of base and lower Freq. Smaller subs are usually tight. I run a 15" and a 10/12" Velo's
    engtaz
  • goingganzo
    edited May 2007
    that is not true. it all depends on the motor strenth and other factors. if you have 2 of the same cars and one has a 200 hp motorand the other one has a 300 hp motor with one will be faster? same thing for speakers the motor strenth decides how fast the cone can respond to the demand along with power. and the type of box will also change how good the sub can make the fr you desire.
  • G-2
    G-2 Posts: 533
    edited May 2007
    We'd probably spend the money on front and center channel speakers, given your current set up. Good luck and enjoy!
    Chane
    A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
    Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
    Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
    2 - Channel
    Polk
    RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
    Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
    Premier Rack|Blue Jeans,Audioquest,Monster Cables|
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    goingganzo wrote: »
    So your saying that a 10" can move as much air as a 15"??
    engtaz
  • kingkip
    kingkip Posts: 401
    edited May 2007
    kalgiers wrote: »
    Common misconception. At 20Hz the wave is about 55 feet long. Not too many people have that much space between their sub and themselves and yet they still seem to hear it fine.
    There are two ways to argue with women. Both of them are wrong.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited May 2007
    for big subs you need a large room to get the lare wave form too fully form and too really appreciate other wise its the simple pressure wave ....
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Face
    Face Posts: 14,340
    edited May 2007
    engtaz wrote: »
    Look at the amount of air this 12 moves. There's more than just the driver's diameter. http://edesignaudio.com/edv2/ednews/home/blog.php?id=102
  • goingganzo
    edited May 2007
    yes but if you can move the air should you? if the subs motor is not strong enough to move the cone fast enough over the distance your bass will sound loose. and that is why a 15, 18 can sound good you just need a powerfull motor to move the cone.
  • kingkip
    kingkip Posts: 401
    edited May 2007
    Again a 20hz wave is 55' long. Not many people have a home theater that big, so are you saying that they never hear the full sound? It doesn't work that way.
  • engtaz
    engtaz Posts: 7,672
    edited May 2007
    When it alters your heart beat it's set up right. LOL
    engtaz
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2007
    I was talking to a dealer for JL home subwoofers, and he said that some people with smaller rooms in houses in the midwest (he said they were built air tight due to the wind) that the JL Gotham sub was causing minor structural problems and flexing windows. But that is the extreme side of things. In general then, no, you can't really go too big.
