7.1 worth it over 5.1
xMEATx
xMEATx Posts: 15
I am considering adding two more speakers to my system. Is it worth it at this point? I have not seen alot of material that is 7.1. Your thoughts please.
Post edited by xMEATx on
  • Sami
    Sami Posts: 4,634
    edited April 2007
    Depends. I have the room now for 7.1 but I dediced to stick with 5.1, especially since I can get HD soundtracks only in 5.1. Room dimensions would be good background info.
  • xMEATx
    xMEATx Posts: 15
    edited April 2007
    The room is about 20 x 20.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Acoustic nightmare. Box rooms are hard on reflections. Is that the dimmisions for all audio or are you splitting the room up. I like 7.1.
    engtaz
  • Serendipity
    Serendipity Posts: 6,975
    edited April 2007
    I only have a 5.1 system even though my receiver is 7.1. I'd rather have good speakers over more speakers.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    xMEATx wrote: »
    Definatly 7.1 You have alot of space to fill up. And more and more movies are going 6.1
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    With the width of your room you definitely need 7.1.
    engtaz
  • Sansui
    Sansui Posts: 372
    edited April 2007
    What about a 12' x 13' living room? 7.1 "worth" it?
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    appadv wrote: »
    Excellent point. Speakers, and amps in my case. Also setting up the side speakers (surrounds) next to you is annoying, and hard to adjust the levels if you have a couple people not sitting dead center. I like my surrounds behind me.
    Enjoy Ben
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited April 2007
    Sansui wrote: »
    I've got about the same size room and I'm running 6.1 after running 5.1 for 2 years here. The improvement was definitely worth while. Stuff that was coming from behind you would sound like it started beside you and went forward, now it sounds as if if comes from behind or above you, and my rear center is sitting on the floor facing up(in an apartment and can not mount it on the wall).
  • Sansui
    Sansui Posts: 372
    edited May 2007
    Do you have a 7.1 AVR like I do? If so, where to I find hookup info for 6.1? My manual only shows 5.1 and 7.1...
  • Willow
    Willow Posts: 11,231
    edited May 2007
    appadv wrote: »
    I'd rather have well positioned speakers over more speakers.
    It won't hurt to go 7.1, you be set up for the future. But like I said I'd take a 3.1/5.1 which is set up the right way over 7.1 which is put up like ****
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited May 2007
    My room is about 13 X 17 and I sit right in the middle of the room. I have set up 7.0 system (no sub-woofer yet). I am amazed at how good just regular old TV sounds (things with Music like American Idol) when running in Dolby IIxc mode. I guess some shows are broadcast in Dolby Surround mode and Dolby IIxc does a good job of spreading that out over the 7 channels.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • xMEATx
    xMEATx Posts: 15
    edited May 2007
    I do have 7.1 avr. My set up is if I want to do 6.1, I use the left surround back out put. I dont know if that is the same as yours.
  • Nisqually Dave
    Nisqually Dave Posts: 220
    edited May 2007
    Will srs 1.2tl work in a surround system
  • zingo
    zingo Posts: 11,258
    edited May 2007
    I can't stand surround modes when I watch TV. It just always sounds weird to me. Maybe I'm just behind the times, but I think that TV and music should be two channel.
    Dave, there are many people who run SDA home theaters. I believe both of these guys use them.
    http://www.polkaudio.com/forums/showcase/view.php?userid=67759
    http://www.polkaudio.com/forums/showcase/view.php?userid=70831
  • Eric W
    Eric W Posts: 556
    edited May 2007
    I like 7.1 over 5.1, provided you can set up the 7.1 properly- this includes *not* having the couch backed up to the rear wall. But having both side and surround back speakers the same height, same line of speakers (ideally the same model) and less important the same distance from the listening areas.
    The receiver/processor will sythesize the #6 and #7 channels based on the #4 and #5 channels to create an enveloping sound field.
    FWIW I use 2 pairs of LSiFX in a 13.5x17" room and it sounds great.
    -Eric
    -Polk Audio
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Use a sound meter and adjust as need to get the same reading on each speaker.-sub
    engtaz
