7.1 worth it over 5.1
xMEATx
I am considering adding two more speakers to my system. Is it worth it at this point? I have not seen alot of material that is 7.1. Your thoughts please.
Post edited by xMEATx on
Depends. I have the room now for 7.1 but I dediced to stick with 5.1, especially since I can get HD soundtracks only in 5.1. Room dimensions would be good background info.
The room is about 20 x 20.
Acoustic nightmare. Box rooms are hard on reflections. Is that the dimmisions for all audio or are you splitting the room up. I like 7.1.engtaz
I only have a 5.1 system even though my receiver is 7.1. I'd rather have good speakers over more speakers.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Definatly 7.1 You have alot of space to fill up. And more and more movies are going 6.1Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
With the width of your room you definitely need 7.1.engtaz
What about a 12' x 13' living room? 7.1 "worth" it?Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN... -
Excellent point. Speakers, and amps in my case. Also setting up the side speakers (surrounds) next to you is annoying, and hard to adjust the levels if you have a couple people not sitting dead center. I like my surrounds behind me.
Enjoy BenPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I've got about the same size room and I'm running 6.1 after running 5.1 for 2 years here. The improvement was definitely worth while. Stuff that was coming from behind you would sound like it started beside you and went forward, now it sounds as if if comes from behind or above you, and my rear center is sitting on the floor facing up(in an apartment and can not mount it on the wall). -
Do you have a 7.1 AVR like I do? If so, where to I find hookup info for 6.1? My manual only shows 5.1 and 7.1...dudeinaroom wrote: »I've got about the same size room and I'm running 6.1 after running 5.1 for 2 years here. The improvement was definitely worth while.Be gentle, I'm new to all this...
I'd rather have well positioned speakers over more speakers.
It won't hurt to go 7.1, you be set up for the future. But like I said I'd take a 3.1/5.1 which is set up the right way over 7.1 which is put up like **** -
My room is about 13 X 17 and I sit right in the middle of the room. I have set up 7.0 system (no sub-woofer yet). I am amazed at how good just regular old TV sounds (things with Music like American Idol) when running in Dolby IIxc mode. I guess some shows are broadcast in Dolby Surround mode and Dolby IIxc does a good job of spreading that out over the 7 channels.Robert
zombie boy 2000 wrote:You are officially in the high-end of the deep-end of the top-end.
Bonus Room Over Garage:
Toshiba 27" CRT TV
Digital Source: Sony DVP-NS3100ES
DVR: Panasonic DMR-ES15
Denon 3806 AV Receiver
- L/R Preamp out to Parasound HCA-1200 Amp
Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
Living Room: (2ch only)
TV: Sony KV20-FV12
DVD Player: Sony DVP-NS715P
Yamaha R9 Receiver Polk RTi38's -
I do have 7.1 avr. My set up is if I want to do 6.1, I use the left surround back out put. I dont know if that is the same as yours.
Will srs 1.2tl work in a surround system
I can't stand surround modes when I watch TV. It just always sounds weird to me. Maybe I'm just behind the times, but I think that TV and music should be two channel.
Dave, there are many people who run SDA home theaters. I believe both of these guys use them.
http://www.polkaudio.com/forums/showcase/view.php?userid=67759
http://www.polkaudio.com/forums/showcase/view.php?userid=70831 -
I like 7.1 over 5.1, provided you can set up the 7.1 properly- this includes *not* having the couch backed up to the rear wall. But having both side and surround back speakers the same height, same line of speakers (ideally the same model) and less important the same distance from the listening areas.
The receiver/processor will sythesize the #6 and #7 channels based on the #4 and #5 channels to create an enveloping sound field.
FWIW I use 2 pairs of LSiFX in a 13.5x17" room and it sounds great.-Eric
-Polk Audio -
Use a sound meter and adjust as need to get the same reading on each speaker.-subengtaz
