the difference between sda-srs and sda-srs 1.2
tom t
hello, can anyone tell me if there are any physical differences between the
sda-srs and the sda-srs 1.2tl. im going to look at a pair tomorrow and the seller says they are 1.2's but not sure. would it say 1.2tl on the back of the cabnet??. is there a difference in sound between the two.
these are the ones some members were discussing a few weeks back. the ones in pa. seller is asking $1600 for them. i want to take a good look at them befour i buy them. one member dident like the way the drivers looked,
some dust cones pushed in. im sot worried about that as long the speakers work. i would just like to know what model they are. any help would be appreciated. thanks
Post edited by tom t on
1.- The TL's will have a screw/bolt in the back, about 2/3 high. This is for the bass brace
2.-The TL tweeters will be dark, while the SDA-SRS will have silver tweeters (the dome).
3.- The TL will have a pin-blade interconnect, while the SDA-SRS will have a blade-blade.
4.- I know there's a difference in the crossover plate, but I don't remember now how it goes._________________________________________________
thank you for the info. you were very helpfull.
i will check it all out -
thanks htrookie, just heard back from seller. speakers are not 1.2. has
everything you said it would to be a sda-srs. im going to pass on them,
was hoping for newer version. thanks again
