the difference between sda-srs and sda-srs 1.2
tom t
tom t Posts: 543
edited April 2007 in Vintage Speakers
hello, can anyone tell me if there are any physical differences between the
sda-srs and the sda-srs 1.2tl. im going to look at a pair tomorrow and the seller says they are 1.2's but not sure. would it say 1.2tl on the back of the cabnet??. is there a difference in sound between the two.
these are the ones some members were discussing a few weeks back. the ones in pa. seller is asking $1600 for them. i want to take a good look at them befour i buy them. one member dident like the way the drivers looked,
some dust cones pushed in. im sot worried about that as long the speakers work. i would just like to know what model they are. any help would be appreciated. thanks
Post edited by tom t on
