CRS+ placement and sound
NeilGabriel
NeilGabriel Posts: 1,487
edited April 2007 in Vintage Speakers
After getting some nice used CRS+, I was unsure about the sound and was having trouble with the room I was using (a huge finished rec room in basement a/k/a media room). I have moved them upstairs to my home office--about 10 by 12-- and placed them on hip high bookshelves. Only about 40 inches apart and each is about a foot from a sidewall. The sound is terrific. I rearranged the office so I sit facing them in the sweet spot. I might never go to my real office again!
Post edited by NeilGabriel on
  • amulford
    amulford Posts: 5,020
    edited April 2007
    Can you spread them out a little more? If you can get 6' between them and put them less than 1' from a back wall it'll be even better...
  • NeilGabriel
    edited April 2007
    Back space might be 2 inches...not enough room to get 6 feet in between unless they abut side walls...I could check that out. So, where are the danish and bagels this morning??
  • engtaz
    engtaz Posts: 7,675
    edited April 2007
    amulford,
    Is correct, The 6' is for sda imaging and 1' is for better over all sound.
    engtaz
