CRS+ placement and sound
NeilGabriel
After getting some nice used CRS+, I was unsure about the sound and was having trouble with the room I was using (a huge finished rec room in basement a/k/a media room). I have moved them upstairs to my home office--about 10 by 12-- and placed them on hip high bookshelves. Only about 40 inches apart and each is about a foot from a sidewall. The sound is terrific. I rearranged the office so I sit facing them in the sweet spot. I might never go to my real office again!
Post edited by NeilGabriel on
Can you spread them out a little more? If you can get 6' between them and put them less than 1' from a back wall it'll be even better...
Back space might be 2 inches...not enough room to get 6 feet in between unless they abut side walls...I could check that out. So, where are the danish and bagels this morning??
amulford,
Is correct, The 6' is for sda imaging and 1' is for better over all sound.engtaz
