Got the sub hooked up.
MSALLA
I finally had the time to get my sub hooked up. It's a svs 12.1 driver (purchased on here) in a 48" x 16" sonotube. I have it hooked to an outlaw m200 amp (325w @ 4ohm). It sounds great. Not boomy and pulls much lower then my PSW 303. However, I was expecting it to have more volume (louder). Not sure if it's not enough power but SVS told me to use 300wpc. Any suggestions?
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
Post edited by MSALLA on
I have the 12.1 with a Rythmik audio amp. 380@4ohms in a 4.2cuft incloser. No..the 12.1 is not loud, but it does preasurize my 16' x 22' x 8' room pretty well.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
The amp should provide plenty of power. Play around with placement. How big is your room? If you have a fairly large room, your experience is understandable.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
25' x 12' x 9' room. It sounds great and I can live with it, but I was hopeing for more.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
That's a big room treat you self to another.:Dengtaz
Might be several things...ping Ed or Tom. Off the top my head, it could be the room/placement (1st choice), but maybe it's a combination of the tube volume and amp with no rumble filter. Without protection below 16hz, you might be wasting power trying to make the driver go beyond it's limits (that's a total guess, I'm dangerous not knowledgeable). I'd think you should probably max out volume ~ 106-109dbs.
Have you run any tones to find out what your FR is?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Ron Temple wrote: »
Not yet. I should have time tomorrow.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
Thats a big room to expect a lot of volume from a single driver sub.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
I am thinking the same thing. I guess it's time to build another one.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
Great idea. For that size room, two sonosubs would be awesome. Plus, for 2-channel, you'll have stereo subs. Oh, yeah!HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
This is going to take some jewelry to counter the negative WAF.
Keep in mind, this is in my living room. Two black tubes just shy of 5 foot is not going to go over well.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
this is very common as people are coming from lesser quality subwoofer and then replace them with the likes of an SVS.. they say the sound isn't as loud..
well you can always raise the volume.. but in the end.. the subwoofer is just doing what it was built to do.. dig low and deep.. ie: more accurate than alot of other subs.
crank the sub to your liiking. you will not damage it.. people always run their subwoofers hotter than the rest of their speakers... crank it up!!!!!PolkFest 2012, who's going>?
danger boy wrote: »this is very common as people are coming from lesser quality subwoofer and then replace them with the likes of an SVS.. they say the sound isn't as loud..
+1000
People are used to hearing that annoying 40-70hz loudness. The SVS has a very flat Fr responce way below 40hz. With a proper rumble filter (like on my Rythmik audio amp) , the SVS sub can reach levels of dBs way beyond most. And once you get used to the "dissapearence" of the SVS, the other "subs" just seem like hollow coffins.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I was wondeing about that. I never had a good sub before. The best was the Psw 303 I just replaced. It sounds great and I feel it more than hear it. I guess it is more my lack of knowledge then anything else.
Can I buy a rumble filter by itself?Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
After a vey bad day at work, I got home and had a 1/2hour by myself. I poped in a cd and played with the settings. HOLY BASS!!!!!!
Much more musical then the polk sub. Clean crisp tight bass. I still my make another one because , well lets face it, it would be very cool.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
