Help Converting VHS to DVD
jgido759
I'm looking for information on how to transfer some old family VHS tapes on to DVD. Does anyone know of a program, either shareware or for a nominal purchase, to accomplish this? Also, what type of sound/video card is needed to connect a VCR to a computer?
Thanks in advance.
Thanks in advance.
Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection
-Drew Carey
-Unknown
My DVD Collection
Post edited by jgido759 on
I would just use a standalone DVD recorder. That way you don't need a computer, hard drive, or capture card.
Something like a Panasonic DMR-E95HS would work fine for this purpose.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
What appadv said.
I am using a Panny DMR-100HS to transfer my old Beta and VHS race tapes and it works good.
Yes even the old Beta still kicks VHS in the weeds for quality and resolution.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Hauppauge USB2 WIN-TV PVR
This will let you load video onto your computer and save it to DVD or just to the hard drive. You can edit the video too if need be with the included software. The main point of this unit is to feed TV into your computer, but it is basically a video input device with a TV tuner. That and it all connects via USB so you don't have to open up your computer to install any new hardware.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
Thanks for all of the replys.
edbert, I think that might be the way to go. $100 is not that bad.Oh, you hate your job? Why didn't you say so? There's a support
-Drew Carey
-Unknown
My DVD Collection -
Probably not if you only have a few to do.
Last count I had over 100 to transfer and wanted it to be free from my computer.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
There are many ways to accomplish this. I would agree one of the easiest is to use just a set top DVD recorder should you wish to bypass the learning curve associated with the many SW/HW choices one has for a PC approach.
My favorite reference site is hereSDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES
