Help Converting VHS to DVD
jgido759
jgido759 Posts: 572
edited April 2007 in The Clubhouse
I'm looking for information on how to transfer some old family VHS tapes on to DVD. Does anyone know of a program, either shareware or for a nominal purchase, to accomplish this? Also, what type of sound/video card is needed to connect a VCR to a computer?
Thanks in advance.
Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection
Post edited by jgido759 on
  • Serendipity
    Serendipity Posts: 6,975
    edited April 2007
    I would just use a standalone DVD recorder. That way you don't need a computer, hard drive, or capture card.
    Something like a Panasonic DMR-E95HS would work fine for this purpose.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • read-alot
    read-alot Posts: 812
    edited April 2007
    What appadv said.
    I am using a Panny DMR-100HS to transfer my old Beta and VHS race tapes and it works good.
    Yes even the old Beta still kicks VHS in the weeds for quality and resolution.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • edbert
    edbert Posts: 1,041
    edited April 2007
    Hauppauge USB2 WIN-TV PVR
    This will let you load video onto your computer and save it to DVD or just to the hard drive. You can edit the video too if need be with the included software. The main point of this unit is to feed TV into your computer, but it is basically a video input device with a TV tuner. That and it all connects via USB so you don't have to open up your computer to install any new hardware.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • jgido759
    jgido759 Posts: 572
    edited April 2007
    Thanks for all of the replys.
    edbert, I think that might be the way to go. $100 is not that bad.
    -Drew Carey
    -Unknown
    My DVD Collection
  • read-alot
    edited April 2007
    Probably not if you only have a few to do.
    Last count I had over 100 to transfer and wanted it to be free from my computer.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • eeagle
    eeagle Posts: 226
    edited April 2007
    There are many ways to accomplish this. I would agree one of the easiest is to use just a set top DVD recorder should you wish to bypass the learning curve associated with the many SW/HW choices one has for a PC approach.
    My favorite reference site is here
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
