MUST GO -- two 12" Audiobahn 550 wrms subs -- CHEAP
PoweredByDodge
*** MUST GO ****
TWO EACH -- Audiobahn AW121-T Subwoofers
12"
550 watts rms / 1,100 peak
single 4 ohm voice coil
Asking
$ 80 for the PAIR ( $40 each ).
Retail = $190 each.
Current old stock price new = $109 (http://www.woofersetc.com/index.cfm?fuseaction=product.display&product_id=1883)
PHAT 2 Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3 Coated Cone for Low Cone Distortion
Flame Design Chrome Stamped Steel Basket
Magnet Weight - 80 oz.
Frequency Response - 26Hz - 1kHz
Efficiency 92.8dB
Mounting Depth - 5-5/8"
Hole Cutout - 11-1/8"
Outer Diameter - 12-3/4"
12"
Asking
Retail = $190 each.
Efficiency 92.8dB
The Artist formerly known as PoweredByDodge
Post edited by PoweredByDodge on
where are you located?
Buffalo, New York (zip = 14220).
local pickup is fine, or shipping would be actual ups/fedex/postoffice (your choice). no charge for packing or boxing.The Artist formerly known as PoweredByDodge -
Why are you getting rid of em?
Those flames make them too hot to handle
Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
exalted512 wrote: »Why are you getting rid of em?
-Cody
Because I do not need them. When I did the build for SQ comp, I did a lot of stuff that wasn't necessarily what I wanted, but what I was asked to do. One of those was running iso clamshells. The idea was cool, but in the end, I wasn't "me".
Last year, I had a falling out, and pulled everything. I redid the truck the way I wanted it, and said 'to hell with comp'.
So I scrapped the highs (not only were they toast, but i had modified them in such a way that they weren't practical to re-use), and the subs I just put in the closet. I had two 10's and two 12's. I sold one of the 10's. The other one I'mgonna use. The two 12's are just taking up space.The Artist formerly known as PoweredByDodge
