Subwoofers Polk versus Boston Acoustics
giddavr
giddavr Posts: 13
edited April 2007 in Speakers
Hi
I am from India.
Need advise regarding Sub Woofers.
How does Boston Acoustics compare with Polk Audio Subwoofers for Home Theatre
Post edited by giddavr on
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Look into SVS.
    engtaz
  • giddavr
    giddavr Posts: 13
    edited April 2007
    Cant get them in India
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2007
    Welcome Giddavr.
    I have never heard a Polk sub. However, I have a BA sub & I like it just fine for my small room. It supplements the bass in my music perfectly & adds enough BOOM to my movies for my taste.
    It won't rattle my walls, but then again, I'm not sure I want it to since I want to keep the peace with my neighbors.
  • JoshParsons84
    JoshParsons84 Posts: 565
    edited April 2007
    I dont care about keeping peace with my neighbors. Neighbors are there to annoy you and call the cops on you when you dont want them to.
  • JoshParsons84
    edited April 2007
    Giddavr, get the biggest baddest sub you can afford and hook it up buddy!
  • cfrizz
    edited April 2007
    And it's ignorant & inconsiderate comments like these, as well as your asinine questions to which you never heed the answers why I have you on ignore!:rolleyes:
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    Boston Acoustics hasn't made a worthwhile product in years.
  • powerlord
    powerlord Posts: 310
    edited April 2007
    dorokusai wrote: »
    I agree totally,BA's are muddy and boomy! It depends on how much money you want to spend on a Polk as to what kind of bass you'll get.But I would pick Polk hands down over BA.:)
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
    http://members.soundclick.com/powerlord66
  • dorokusai
    edited April 2007
    Sweet Eosone setup Powerlord :)
  • powerlord
    edited April 2007
    Thanks Doro!:)
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • Monster Jam
    Monster Jam Posts: 919
    edited April 2007
    I'm gonna shoot from the hip and make a largely unfounded statement, so, for what its worth (and its probably not worth a whole lot)...
    Depending on your price point (and for arguments sake, lets say $300 - $600 shipped), I don't think you'll see a lot of variation between products among the larger commercial brands. Stated differently, I think they will sound very comparable. They may even share some components and/or construction facilities as well.
    I guess what I'm saying is that if your going to spend less than $600 on the sub, if your buying a major brand, there isn't enough difference between them to justify a long drawn out analysis over the internet.
    Caveat: By major brands I mean BA, Polk, Yamaha, Cambridge, etc.
    Do you hear that buzzing noise? :confused:
  • PolkThug
    PolkThug Posts: 7,532
    edited April 2007
    The Polk PSW-505 is a good sub for most applications.
  • bknauss
    bknauss Posts: 1,441
    edited April 2007
    BA makes subs? They're not on my radar as competition.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Velodyne
    engtaz
  • cfrizz
    edited April 2007
    They did 5 yrs ago Brian.
  • giddavr
    giddavr Posts: 13
    edited April 2007
    PolkThug wrote: »
    I am only interested in HT and not music.
    My setup - ONKYO TX – SR 504 AV RECEIVER
    OPPO OPDV971H Upconverting DVD Player
    SONY Grand Wega 50” KF-E50A10 3LCD RPTV
    Front - SONY SS-BX6AV 2way Bass Reflex Bookshelf Speakers
    Center -– Dayton 2 way sealed Enclosure
    Rear -– Sony SS-RS106 10cm. Full Range Bass Reflex - NO SUB.
    Dont ask me why I am using those Sonys. They are from an old setup before I got the new TV, AVR and Oppo. Now I need to setup a proper Speaker system for my HT.
    I am thinking of Polk RTi 8 or 10 as FS, CSi 3 or 5, RTi 4 or FXi3 for SC.
    Would you say PSW-505 will be GOOD enough as a SUB compared to the SVS PB10NSD for HT.
    My room is 20' x 20' x 9'.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Velodyne is great for HT I run a Velo 15 and a Velo 10/12
    engtaz
  • gvg45
    gvg45 Posts: 53
    edited April 2007
    giddavr wrote: »
    IMO, the SVS PB10NSD is the MUCH better choice for HT.
    Given your size room, you may even want to at least consider the SVS PB12NSD.
  • giddavr
    giddavr Posts: 13
    edited April 2007
    Is Velodyne of same quality as SVS
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    SVS is considered one of the best for music. Velodyne is very good and gets great reviews. I don't know what the others think but for me it's one the the best out there for HT and music combined. They are very well made and customer service is very good. You could not go wrong getting a Velodyne. Music requires a tighter bass and SVS comes thought better on the tight bass then the Velodyne (not that the Velodyne is not tight). The velodyne is not bad for music just not as tight as the SVS but for HT its great.
    Hope that answered you question,
    engtaz
    engtaz
  • gvg45
    gvg45 Posts: 53
    edited April 2007
    engtaz wrote: »
    engtaz
    SVS considered the best for music, IMO, I would have to disagree. I believe SVS is considered one of the best for HT. I would think JL, Velodyne (DD series), & HSU would be considered best for music. The DD series from Velodyne are really top notch performers. The other models are not of the same quality, given their price points.
    These are my opinions and I'm sure others will agree and disagree.:)
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    That should help answer the question "Is Velodyne of same quality as SVS".
    By the way I own 2-Velodyne's,
    engtaz
  • powerlord
    edited April 2007
    engtaz wrote: »
    By the way I own Velodyne,
    I remember hearing my first Velodyne sub in a shop where they had a room for HT and the Velo was a spl1200r and I was awestruck!I went back months later and heard an HGS15 and was totally blown away.I love SVS due to owning one now,but I can't compare my PC 20-39 to that spl1200r.The Velo puts it to shame,but my SVS is an older one and it pooped out,waiting for the new bash amp and sub.So maybe there will be a significant improvement.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • Monster Jam
    edited April 2007
    I run the SPL1200 series II. Its my little shiny baby! :)
