small hum coming from sub
d-staylor@hotma
I have 2 PSW-1000 subs one is near the front speakers the other is 3 feet behind my couch. The one near my fronts has a small humming sound, if I turn my reciever all the way down no humming, once i turn it up or power the sub on it will hum. Any suggestions? Thanks
Post edited by d-staylor@hotma on
If you can, use a separate outlet for the sub."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What happens if you swap them? Does the hum follow the sub or the location? If location - probably some sort of ground loop issue. If location - the sub is not functioning properly and will probably need service.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
d-staylor@hotma wrote: »I have 2 PSW-1000 subs one is near the front speakers the other is 3 feet behind my couch. The one near my fronts has a small humming sound, if I turn my reciever all the way down no humming, once i turn it up or power the sub on it will hum. Any suggestions? Thanks
D - does the sub hum when its active (LED is green) and the volume is all the way down on the receiver? If not, sounds like either some noise from the outlet or from before the sub in the audio chain.Brian Knauss
ex-Electrical Engineer for Polk
