*Sigh* I bought a 360 today
Ill have a wireless controller.
Each of my friends bought a wired controllers. Actually I bought them and they are going to pay me back. Haha -
But TV, definite must after audio upgrades are made...
GOW = yep as soon as some extra funds come up...
Gold Live account - maybe when the upgrade bug subsides...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey,
If you split from a router's LAN port with another router, you have to disable DHCP, NAT, ip forwarding, etc. on the 2nd router otherwise it will NOT work! (I've worked in networking for 4+ years in a government job)...
You're better off getting a network switch to do the job instead.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Im assuming an Ethernet switcher - a place like say - Radioshack and Circuit City would carry, correct?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yes. Just not a router! Otherwise you will have to do this:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=2804050&action_code=5&highlight_info=16777286,133,140&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=826828#__highlight
And, even if you do it correctly you might not even get it to work. Trust me, I've done this on high-end Cisco units and it's not a guarantee. Something like a 4-port switch will do.
What happened to your old XBOX?polkaudio RT35 Bookshelves
I'd suggest you read the article too...so you understand what's going on when you use two routers.polkaudio RT35 Bookshelves
I hit it really hard and the red light of death came on -
Over a game that cost 1.99 none the less. *sigh*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
haha. I remember when you showed me your system you said the XBOX was the "most expensive" source at the time...not anymore
Anyways, congrats on the purchase.
You can get something like this: http://www.circuitcity.com/ssm/Netgear-Gigabit-Ethernet-Switch-GS605NA/sem/rpsm/oid/123393/catOid/-12980/rpem/ccd/productDetail.do
It's a basic ethernet switch WITHOUT the router portion. Does the job much better and more reliably than a router with the DHCP turned off.polkaudio RT35 Bookshelves
Nah when you were here - I had the Onix - which was about twice the price of my XBox - which was preowned and about 3-4 years after the release.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Right. Now I remember. I think you also laughed at the fact that my ex had a Bose system.polkaudio RT35 Bookshelves
The HD DVD is less than impressive. It does the job fine for me, but if you want great sound look elsewhere.
lip sync issues as well as what they deem to be stuck in "night mode", thus leading to supressed audio. supposed fix has been ready for months, yet has not arrived. getting mad at bill gates about now. as well as multitudes of others.
as far as the 360, do you have a timeframe in which you can still return it? not exactly sure of the date, but the 'elite' is due out soon. it will be black and come with hdmi, but the hdmi for now will only fetch you better video connection. it still will not allow for true hd, which is what hd dvd is supposed to offer. for now, nix the hd dvd drive. the visuals are top notch for sure, but the audio is enough to make me want to ditch it and get a stand-alone hd dvd player.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
Sid,
Also look for a used copy of F.E.A.R. if you get a chance, should be able to come across one fairly cheap. Great game also, and a nice change of pace from GRAW and GoW.
http://cgi.ebay.com/Fear-XBOX-360-First-Encounter_W0QQitemZ140109106779QQihZ004QQcategoryZ62053QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/GEARS-OF-WAR-Xbox-360-Live-Shooter-Action-UNUSED_W0QQitemZ330110862743QQihZ014QQcategoryZ62053QQrdZ1QQcmdZViewItem -
I would rather use Linksys. I have had trouble with Netgear hooking up to WII changed to Linksys and worked right away.
engtazengtaz
You are going to love your 360,when you play GOW or Lost Planet you'll realize that gaming just went to a different level,I was enthralled by GOW.And I have the HD dvd player and it does it's job,but I'm with Demi on the audio,my Ps3 totally stomps the 360 in audio and has a bit of an edge as far as video goes.The 360 is the best game console hands down so far though IMO.:)LG 50 in. Plasma
Eosone setup
Marantz SR-18U
HK AVR-7200
My Music
http://members.soundclick.com/powerlord66
