Need help.
smitty71
smitty71 Posts: 5
edited April 2007 in Speakers
Im new to all this. I recently bought the LSI9 series because they blew me away on display at a store. I was sold an Onkyo SR804 to go with it. I will be using this for HT and 2channel music. I knew nothing about Ohms on speakers until today but now I understand it takes a lot of power to get the best from these speakers.
Im allready over budget but I wont be satisfied until this system cranks. What is the best amp for the $ I can add to my SR804 to get the LSI9's to perform. What is the minimum watts per ch. I can get away with a amp hooked up to my SR804.
Remember, Im trying to keep the amp price as resonable as possible to avoid DIVORCE. Im allready a thousand+ over budget from what I told the wife :rolleyes:
Any suggestions?
Thanks in advance.
Post edited by smitty71 on
  • PolkThug
    PolkThug Posts: 7,532
    edited April 2007
    Welcome to the forum. The Lsi9's are rated at half the resistance of typical speakers (4ohm vs. 8ohm). So, the Onkyo may exert itself too much at higher volumes and go into protect mode.
    How big is your room? How far away from the speakers are you?
  • unc2701
    unc2701 Posts: 3,587
    edited April 2007
    Adcom 555. It's the minivan of power amps, but like Billy Dee says, it works every time.
    Should be able to score one on ebay for ~$300-$400.
    Backburner:Krell KAV-300i
  • smitty71
    smitty71 Posts: 5
    edited April 2007
    PolkThug wrote: »
    The rooms is about 15X20. Im sitting about 15 feet from my TV. Won't adding a amp get rid of the problem of my Onkyo going into protect mode?
    Should I return the receiver to get a different reciever that can handle the LSI9's? If so which reciever that has all the HT options of the Onkyo sr804. I really like the HDMI and upscaling features of the onkyo SR804.
    Or keep the Onkyo sr804 and buy a amp?
    I am on a slight budget. I really dont want to spend more then about $1200 bucks on a nice receiver or $1200 bucks on a decent receiver and a amp combo. Whats the better way to go?
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Adcom GFA-555
    US $325.00 BIN
    Shipping costs: US $50.00
    http://cgi.ebay.com/Adcom-GFA-555-Am...QQcmdZViewItem
    engtaz
    engtaz
  • smitty71
    smitty71 Posts: 5
    edited April 2007
    engtaz wrote: »
    Adcom GFA-555
    US $325.00 BIN
    engtaz
    I know the amp will make my left and rights crank when listening to music but can the Onkyo SR804 handle the lsi'9's left, right, and center when Im running 5.1 watching movies at a medium volume? The SR804 specs says it supports 4ohms... im such a newb...
    If I buy the amp and then start watching my first 5.1 movie with my wife and my reciever powers down, im headed for divorce court:o
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    smitty71 wrote: »
    Any suggestions?
    Thanks in advance.
    Yes, get a new wife. :p
    PolkFest 2012, who's going>?
  • JimBRICK
    JimBRICK Posts: 1,543
    edited April 2007
    yeah if you just get a nice 2 channel amp to run the lsi's you'll be ok. They have TONS on ebay. every name brand you can think of
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • JimBRICK
    edited April 2007
    2 CHANNEL
    Under construction
  • smitty71
    smitty71 Posts: 5
    edited April 2007
    JimBRICK wrote: »
    Do I need to get a 3+ channel amp to support my LSIC also? Would the ADCOM GFA-7605 at $799 make this system perform with the SR804? Or can I get away with the 2ch amp for right and left and let the SR804 power the LSIC center?
  • JimBRICK
    edited April 2007
    I'm getting a 3 channel and I have the same setup coming. the adcom is an awesome amp. I think that price is about 100 bucks to high tho I've seen them lower
    2 CHANNEL
    Under construction
    edited April 2007
    3 channel for the front 3 speaks....whats doing surround duty?
  • smitty71
    smitty71 Posts: 5
    edited April 2007
    tonyb wrote: »
    The ADCOM GFA-7605 is a 5ch amp.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2007
    You could do 3 outlaw audio M2200 Monoblocks. they are rated at 300 watts @4ohms. 3 of them would set you back 921.00 or you could look on Audiogon and find sweet deals there on Adcoms all day.
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    Get an Adcom GFA-555, and your 2 channel will sound great. Look on audiogon, and ebay. You should be able to score one for under $400 shipped. Use the rest of your reciever for HT (center, and surrounds).
    Ben
