need specs for eosone 6.5" woofer
vroden
vroden Posts: 1
edited April 2007 in DIY, Mods & Tweaks
hello all,
i am rebuilding my horrible sounding computer speakers using some eosone drivers. unfortunately, the search for thiele-small paramters for this eosone woofer proved unfruitful. <http://cgi.ebay.com/6-1-2-EOSONE-POLK-1RD0006-2-WOOFERS-FOR-RSR-350-NEW_W0QQitemZ280103121875QQihZ018QQcategoryZ32861QQcmdZViewItem&gt;
i wonder if anyone can provide some specs for it. or maybe i would be better off with another manufacturer's specs of a comparable woofer and go from there? thanks for any help anyone can provide.
Post edited by vroden on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited April 2007
    don't use specs from a similar driver they will most likely be wrong.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited April 2007
    If you buy one they should have a spec sheet or simply call POLK
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    I tried those woofer, and the sound wasn't as good as Polk MW65xx woofer. They are also less efficient.
    Ben
