Is 1000 wpc too much for Maggie 1.6qr's?
candyliquor35m
candyliquor35m Posts: 2,267
edited April 2007 in 2 Channel Audio
Right now I'm running just one 375 wpc carver and on some albums I have to move the volume to 12 o'clock and would even like to go a little louder. I have another identical carver that I could add and go mono at 1000 wpc but I'm wondering if a step up unit would suit my needs better?
I can tell the maggies are a little power hungry because they make the lights on the carver dim with the beat of the music and Polks never did that.
But being that I have the carver already should I try it first?
My tt is a techniques sl-1800 and at440mla cartridge.
Post edited by candyliquor35m on
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited April 2007
    Which amps are they? I know that most Carver amps don't like to run bridged at 4 ohms, and the Maggies are 4 ohms right? I guess there is a heat issue....F1NUT has more knowledge about this than I do, but I didn't want you to ruin a pair of amps in the process....Those are expensive fix....
  • strider
    strider Posts: 2,568
    edited April 2007
    There was a post at Carveraudio.com regarding running (I think) M500's bridged. Let me see if I can dig it up....
    Nevermind, it was regarding running a set of 6 ohm speakers with 2 M500's bridged. Didn't seem to come to a solid conclusion, either.
    Wristwatch--->Crisco
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    What amps are a 1000 watts mono?
    engtaz
    engtaz
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    I think Carver TFM-45s and Carver M4.0ts are both around that mark.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • dkg999
    dkg999 Posts: 5,647
    edited April 2007
    Hmmmm, I have a Parasound HCA-1500 running each Maggie 1.6QR, and they can go as loud as I'm comfortable with, without even breaking a sweat! I think the 1.6's tend to dip down below 4 ohms pretty often from what I have read, so maybe that's the problem?
    DKG999
  • Bill Ayotte
    edited April 2007
    Yeah, the carver's aren't rated for 4 ohm mono use.......At least none of the one's whose manuals I have.....
  • candyliquor35m
    edited April 2007
    Good points. I didn't think about the ohm issue. They are a tfm45 and 42, sonically the same amp but one has meters and the other has leds.
    Playing cds are not a problem but when I play albums which is mostly what I'm using this system for right now is when I have to turn the volume to 12 o'clock and only on some albums that I'm rocking out to or that have been recorded or mixed differently.
  • dkg999
    dkg999 Posts: 5,647
    edited April 2007
    Can you use a higher gain phono stage to correct the problem?
    DKG999
  • candyliquor35m
    edited April 2007
    dkg999 wrote: »
    That's what I'm hoping to find out. I don't think my Carver pre- (CT-24) has any adjustments available.
  • candyliquor35m
    edited April 2007
    I thought my tfm-45's owner manual had a warning about running bridged mono with speakers of less than 8 ohms but I don't see it.
    Loudspeaker Load Impedance
    The TFM-42/45 is recommended for driving loudspeaker impedances between 4 and 16 ohms. Loads in excess of 16 ohms will cause a reduction in output power. Sustained loads of much less than 4 ohms may cause premature tripping of protection circuits or cause the fuse to blow.
    Specifications
    Power: 375 watts RMS per channel in 8 ohms both channels driven.
    500 watts RMS per channel into 4 ohms both channels driven.
    1000 watts RMS mono output into 8 ohm load.
  • TroyD
    TroyD Posts: 13,124
    edited April 2007
    Try a higher output cartridge. I'm pretty certain your problem is lack of gain in your phono stage.
    They don't like a 4ohm load when bridged, just be careful.
    I had a similar issue with a previous TT/Cart.
    The TFM 45/42/4.0 bridge to 1000wpc.
    BDT
  • candyliquor35m
    edited April 2007
    TroyD wrote: »
    BDT
    That's what I'm reading on carveraudio.com
    "Yes, if you're running elctrostatics, you are probably better off not running ANY of the Carver stereo amps in bridged mono mode, at least that seems to be the consensus here.
    I used to have a pair of Silver 7ts driving my Martin Logan Sequels, and they sounded FANTASTIC. It was quite an upgrade frommy original amp, a Carver M-200t (which just COULD NOT keep up with the low ohm load of the MLs...)
    I'v never run a Carver stereo amp brided into the Sequels, but I've been considering it, despite what many here seem to say. Carver demonstrated their own ALS speakers at a CES using a pair of M-500t's bridged mono, and those amps are nowehre near as robust as a pair of M-4.0t's or TFM-45s. If they ca do it with that speaker (which is also notorious for presenting a difficult load) then I can't see why ML's would be any problem.
    Of course there are always the Carver "pro" models, which are actually designed to run optimally into 4 ohms, so they should hold up pretty well into 2-ohms and other low-ohm loads that ESLs present...
    Hopefully, I can get a pair of such amps soon, and get th MLs set up. I'll be sure to let everyone know how it sounds, and if the Carvrs start smoking."
  • TroyD
    TroyD Posts: 13,124
    edited April 2007
    The Silver 7/9t's are different than a bridged TFM amp....
    It's not that a bridged amp WON'T work, it's just not designed to. Speaker impedance varies across the range...so it's a moving target.
    My experience with it was the extra power made no difference in sound so why take the risk of damaging gear? YMMV though.
    BDT
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    It would be a waste of an amplifier and hopefully it would blow them up.
    You'd never see 1000wpc in your lifetime on a Magnepan 1.6, as they don't pull bass transients that hard.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2007
    The 45's will work bridged with your speakers, however, I suspect you will hear them run out of power and start to sound bad, as in clipping at the gain you appear to want. This is nothing but the same old watts being the magic number, its simply not the case,never has been, never will be, think power. As you said Carver made mono block amps with this issue in mind, stable to two ohms.
    The suggestion for a higher output cartridge is excellent. Any chance the phono-pre can be adjusted for higher/lower output cartridges. The cartridge may not be able to give you what you are looking for.
    I use "pro" amps with a number of guys for live music, I just do not see them as part of a high-fi home system, just too noisy.
    RT1
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited April 2007
    It's got to be a gain issue on the phono pathway that's causing the issue. Lights shouldn't be dimming or anything.
    1.6QR's aren't THAT needy that you should pulling brown out conditions. I'll run the counterpoint (170w), knights(35W), and adcoms (450W) at the same time to the highs, mids, and lows and have never come close to a brown out. Why:
    The maggies won't even take 1000W. You'll blow the fuses on them at a sustained 100W. If you have bypassed the fuses, you'll blow the wiring at about 200-250W sustained. My guess would be the most a set of maggies can take in a peak would be in the 500W range.
    As you can tell, I really REALLY think that your issue isn't enough power.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • candyliquor35m
    edited April 2007
    Based on everyone's comments, I agree it's a phono gain issue. I can live with it the way it is but just wanted to explore the possibilities.
    Thanks.
    dorokusai wrote: »
    roflol
