Here my LSI Setup
Nice, clean setup man! FWIW, in a room that big I'd go with just an inch of toe-in. VERY NICE.
You know, I was thinking the same about the 'toe in' effect. I'm however a bit confused as I once read in Stereophile magazine that when listening to stereo, the images dispersed from each speaker should merge/coincide in the middle, as if an imaginary floating sphere exists right in front of the listening position; I think the writer even said that you shouldn't even distinguish each speaker per se, the sound coming off each speaker should bond with the sound coming from the other. So if I don't toe them in, it seems to me like the images float by my ears and there's no middle concentric image. How do you guys have your LSI setup, toed in just a bit and slightly angled upwards?Analog:
Polk Audio LSI 15s (cherry) - Fronts
Polk Audio LSI C - center
SVS PB12 Plus Piano Black!! (on its way) - sub
BoseFX - surrounds
Digital:
Panasonic 61" Rear Projection LCD
Parasound Halo A52
Yamaha RX-V1600
Denon DVD3910
Monster Power 1600 Line Conditioner
APC 1500 Smart UPS
Blue Jeans and AudioQuest Interconnects
Logitech Harmony 880 Remote -
Nice. Now you need two more LSi15s for the rear.
Try to angle the center speaker down so that it points directly towards the main audience seating, and see if that makes a differance.
I have a stand for the center speaker in front of the TV. If the movie is letter-boxed I adjust the speaker up so that the top of the speaker is at the bottom of the movie. If the movie is 16x9 then I lower the speaker so that the top is at the bottom of the screen. Along with 2 door stops under the speaker to angle it up, it really makes a differance in sound imaging.
I wish I had a room that big. With that nice wide wall, I would get rid of the ceiling fan and install a projector. If you had a projector and screen then you could use a LSi15 as the center behind the screen.
The nice thing about HT is that it is never quite right. There is always something to do and/or buy. -
Nice gear and excellent job setting it all up, enjoy. Pssssssss dont forget the SVS PB12+ sub. Enjoy bro.Shoot the jumper.....................BALLIN.............!!!!!
. . . I'm however a bit confused as I once read in Stereophile magazine that when listening to stereo, the images dispersed from each speaker should merge/coincide in the middle, as if an imaginary floating sphere exists right in front of the listening position; I think the writer even said that you shouldn't even distinguish each speaker per se, the sound coming off each speaker should bond with the sound coming from the other. So if I don't toe them in, it seems to me like the images float by my ears and there's no middle concentric image. How do you guys have your LSI setup, toed in just a bit and slightly angled upwards?
It all depends on the speakers. Some speakers need more toe in than others to acheive the effect you are describing. If the speakers have very good horizontal dispersion, you may not need any toe in and will still have a good "floating" image. I usually start out with my speakers with no toe in at all and listen to them for several weeks that way with different recordings. Then I may toe them in very slightly and listen for a while with the new setup. Sometimes it takes a little patience to find that "majic" spot where they image best.Robert
zombie boy 2000 wrote:You are officially in the high-end of the deep-end of the top-end.
Bonus Room Over Garage:
Toshiba 27" CRT TV
Digital Source: Sony DVP-NS3100ES
DVR: Panasonic DMR-ES15
Denon 3806 AV Receiver
- L/R Preamp out to Parasound HCA-1200 Amp
Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
Living Room: (2ch only)
TV: Sony KV20-FV12
DVD Player: Sony DVP-NS715P
Yamaha R9 Receiver Polk RTi38's -
Yes, yes, my credit card companies are loving me right now!!Analog:
BoseFX - surrounds
Digital:
Parasound Halo A52
Yamaha RX-V1600
Denon DVD3910
APC 1500 Smart UPS
TN_Polk_Lover wrote: »It all depends on the speakers. Some speakers need more toe in than others to acheive the effect you are describing. If the speakers have very good horizontal dispersion, you may not need any toe in and will still have a good "floating" image. I usually start out with my speakers with no toe in at all and listen to them for several weeks that way with different recordings. Then I may toe them in very slightly and listen for a while with the new setup. Sometimes it takes a little patience to find that "majic" spot where they image best.
Tn_Polk_Lover: I agree, it takes lots of patience, so what I'll do is bring them back so they're almost perpendicular to the listening position, take a listen for a few days and slowly toe them in till I find that 'floating' image.
How about tipping them back a little (ie. raise the front spikes a few inches) so they fire a little upwards towards the ceiling not parallel to the ground?Analog:
BoseFX - surrounds
Digital:
Parasound Halo A52
Yamaha RX-V1600
Denon DVD3910
APC 1500 Smart UPS
I've never experimented with tilting speakers up or down, so I don't really have an opinion on that.
RobertRobert
Toshiba 27" CRT TV
TV: Sony KV20-FV12
