Plasma TV purchase help needed
dragon1952
OK, it seems like every thread like this turns into an LCD vs Plasma debate. As a result you have to sift through 5 pages of responses to try and find any useful info. So please, I am looking at Plasmas.....no LCD comments .... or DLP or whatever
1. Budget of $1500 or less out the door (no sales tax here
2. 42" is fine
3. I am not nor will I ever be into gaming .
4. This will strictly be for watching DVD's and mostly sports on TV. Most likely DirectTV and probably HDTV programming.
5. I don't care if it's the latest model out.
6. I want to hang it on the wall.
I'm looking of course for the best in this price range. I've seen the Panasonic TH-42PX75U for as little as $1265 shipped. Is this one any good?
Thanks for the help!
2. 42" is fine
Post edited by dragon1952 on
th42px60 from panasonic they are a steal right now but if you can get the 75 for that cheap go for it
other than the pioneer I've seen that panasonic has an awesome picture..........and this is coming from a non plasma fan
http://www2.butterflyphoto.com/shop/product.aspx?sku=TH42PX75U
get one of these to go with it, I love mine
http://www2.butterflyphoto.com/shop/product.aspx?sku=URC69602 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
Thanks for the info! I'm a little confused at all the different models. What the hecks the difference between some of these anyway?
Panny TH-42PX75U $1265
Panny TH-42PH9UK $1145
Panny TH-42PX60U $1125
Here's a couple Pioneers. Aren't they supposed to be hot ****? Why is that one only $845?
EDIT: OK..I see, it's just a monitor :rolleyes:
Pioneer PDP-425CMX $845
Pioneer PDP-427CMX $1275
http://www.tvauthority.com//Plasma-TV-Monitors-and-TVs/Plasma-TV-Monitors-and-TVs.asp2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
its the end of the 2006 season so most older electronics are being dumped off. This is always the best time of yearto buy a tv2 CHANNEL
I can get an open box Panasonic TH-42PX60U 42" Plasma HDTV for a little over $900 out the door. I think I'm going to jump on it
Thanks for all the help guys......I mean Jim! :rolleyes:2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
I recently purchased a Panny TH37PX60 and Im thrilled with it.If you can get a 42 for $900 you are crazy not too.
If it is an open box there is a way to find out how many hours it has been used.
Id make sure you have a return policy in case it has a ton of hours on it.Testing
Testing
Testing -
dragon1952 wrote: »Thanks for the info! I'm a little confused at all the different models. What the hecks the difference between some of these anyway?
The TH42PX75 is a brand new model that repalces the TH42PX60
The TH42PH9UK is the pro monitor version that has no tuner or speakers etc.Testing
Testing
Testing -
Thanks for the info! Yeah, I just finally figured out some are just displays and some have tuners. I'm way behind here guys.....sorry. I've been happy with my Mitsu 35" tube for quite awhile now.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
You are right about the LCD/Plasma debate. After evaulation I opted for a 50" Panasonic Plasma. The seating distance IMO is one of the main factors. I am sure you will be happy.Michael
NORTH of 60° -
I like the Samsung for the money.
My seating distance will probably be about 12 ft. I'm sure a 50" would be good for that distance. I had a 50" rear projection many moons ago and sat closer than that. I've been pretty happy with a 35" from about 8-9' for several years though so I'm hoping this 42" will do the trick.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
I think 42" will be fine as I am about 12' feet away from the screen as well.Michael
NORTH of 60° -
I finally decided on projector instead. That way I could chose any size I wanted up to 106". (room size controls scren size)
engtazengtaz
dragon1952 wrote: »I can get an open box Panasonic TH-42PX60U 42" Plasma HDTV for a little over $900 out the door. I think I'm going to jump on it
anytime man thats a SMOKING good price. we were selling them 6 months ago for 2999 CAD2 CHANNEL
engtaz
As long as you have the room for it. -
We also own a Samsung 42" Plasma and couldn't be happier, but that Panny is less expensive and has an outstanding picture.
Good luck and keep us posted!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
Love my Panny 42" TH-42PX60U
Enjoy it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Well I'm still waiting to hear back about the warranty for the open box Panny. In the mean time, assuming the source will allways be a DVD player/cable box/satellite receiver and the sound will allways be external components, is just a plain display the way to go? I mean for the same money or a little less can you get an even better quality display vs something with built-in tuner, sound and HDTV decoder.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I have only 14 ft deep of a room. projectors work from 10 ft out. I have the Mit HD1000U 899 at projectorpeople and 99 for 3 year lamp warranty.
More affordable then plasma or LCD and as big as you want and no screen burn or out of focus scenes from any angle.
engtazengtaz
More affordable then plasma or LCD and as big as you want and no screen burn or out of focus scenes.
engtaz
yep I cant wait to get mine, I bet that huge picture is quite the experience.Shoot the jumper.....................BALLIN.............!!!!!
dragon1952 wrote: »Well I'm still waiting to hear back about the warranty for the open box Panny. In the mean time, assuming the source will allways be a DVD player/cable box/satellite receiver and the sound will allways be external components, is just a plain display the way to go? I mean for the same money or a little less can you get an even better quality display vs something with built-in tuner, sound and HDTV decoder.
That model you listed above 60U has a built-in tuner which can pick up both old analog channels or HD channels.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
My 2 cents (all within your budget):
#1 (quality - amazing): Pioneer (but pricey).
#2 (quality for the price): Panasonic (outpost.com Fry's had a really good deal on 42" a couple of weeks ago, not sure about now).
#3 (cheap, but still good) - Samsung, Hitachi... (saw a really cheap 42" Samsung at CompUSA, which was closing down, but that was 720p/1080i panel).Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I was also looking at the Samsung HP-S4253 for $1145 shipped. Evidently there is a newer replacement model the HP-T4254 I can get for $1225 shipped. I heard the HP-S4253 had a few problems, like with greens and something else and I wonder if the new one has addressed those. The new one does have improved contrast at 15000:1 and a nice anti-glare screen though.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
My mom and dad came down and were floored by the size. They had bought a 42" HDTV. They really like the fact that the was not a bad seat in the house. They could walk right beside the screen and still see it perfectly.
engtazengtaz
I have a pioneer 50" and I can tell you that with my head 10 feet from the screen it is a little too large. At 12 feet you should be fine. Its not that big of a deal, just feel that something around 40" would have been more suitable.
dragon1952 wrote: »I was also looking at the Samsung HP-S4253 for $1145 shipped. Evidently there is a newer replacement model the HP-T4254 I can get for $1225 shipped. I heard the HP-S4253 had a few problems, like with greens and something else and I wonder if the new one has addressed those. The new one does have improved contrast at 15000:1 and a nice anti-glare screen though.
go for the sony grand wega lcd projo. they are much better
http://www.sonystyle.ca/commerce/servlet/ProductDetailDisplay?storeId=10001&langId=-1&catalogId=10001&productId=1003131&navigationPath=32050n452602 CHANNEL
Sorry, but you must be reading impaired. OP's original post quote: So please, I am looking at Plasmas.....no LCD comments .... or DLP or whatever .Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
I quoted his own quote, you need to read before you post2 CHANNEL
Did you not notice that engtaz is suffering from the same impairment?Sorry, but you must be reading impaired. OP's original post quote: So please, I am looking at Plasmas.....no LCD comments .... or DLP or whatever .
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Well actually
uh, I have been kinda sorta looking at the DLP's recently
No LCD's though!!! :mad:2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Some choices so far:
Panasonic TH-42PX75U (new model) Plasma $1265 shipped
Panasonic TH-42PX60U Plasma - $918.96 shipped (open box)
Samsung HP-T4254 Plasma (new model) - $1390 shipped
Samsung HP-T4253 Plasma (old model) - $1145 shipped2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
