Subwoofer repair
1lakerfan
1lakerfan Posts: 112
edited April 2007 in Speakers
I have a Velodyne DLS-4000R. It is making a crackling noise, so im not sure if the subwoofer blew out. Sonemone was messing with my stuff and put the volume real high and after that the subwoofer started making the crackling noise. This is my first surround sytem I have had so I dont exactly know how sounds what the subwoofer blows out. By guessing, how much do think the reapair would cost. The subwoofer retails for about $600 (Cannot use warranty).
Post edited by 1lakerfan on
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2007
    Call Velodyne and see if you can purchase a new sub. Thats the only thing I know to tell you.
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2007
    push on the driver, putting your fingers evenly around the dust cover. push the driver in and out, does it grind a little?, a lot? if so, you might have a fried voice coil, in layman's terms, the driver might be shot. call verlodyne and see perhaps if they have a replacement driver?
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ohskigod
    edited April 2007
    oh, and crack whoever screwed with your system square in the jaw!!!
