Linn Sondek Dust Cover Hinge Repair
SCompRacer
SCompRacer Posts: 9,121
edited October 2013 in DIY, Mods & Tweaks
The Linn Sondek LP12 turntable I recently acquired had a broken hinge on the dust cover and wouldn’t stay open. The other hinge spring was about to pop through. No wonder, with a steel spring rubbing against a thin piece of plastic. I got a quote of around $40 for new hinges that did not appear to be made any better than these, so I decided to fix them and put the dollars toward a better cartridge.
I’ve seen other dust cover hinges designed like this so the repair could work with them. I drilled a 3/32” hole through the hinges and put a slight bend in the leg of the spring. I held the leg of the spring down and inserted the smooth shank of the drill bit through the hole. The excess bit was nipped off with a cutoff disc mounted in a Dremel tool. Now the leg of the spring is held by a metal rod.
The hinges were fixed but they looked shabby from the backside. I split an old computer floppy disk in two and cut some overlay patches out of the thin plastic case. Super Glue was used to adhere the patch to the back of the hinge.
Post edited by SCompRacer on
  • schwarcw
    schwarcw Posts: 7,358
    edited February 2007
    I saw this in person last Sunday. It was a remarkable fix considering I thought the hinges were shot. It looked brand new. Rich never ceses to amaze me with the ingenious fixes he can formulate. My hat's off to you Rich.
    Carl
  • dorokusai
    dorokusai Posts: 25,576
    EXC.
    Yankee engineering, some of the Southern folks might learn something.
  • pblanc
    pblanc Posts: 261
    I need you to come and work on my house. Bring the Sondek.
    Thanks for the kind words.
    Bring the Sondek.
    There were moments during set up I would have given it away.:eek: Good thing I found some patience laying around.:D
  • halo
    halo Posts: 5,618
    You should change your moniker to "Mr. Fixit"!
  • AndyGwis
    AndyGwis Posts: 3,655
    Can I send some of my gear your way for some much needed revitalization?
    Way to go fountain of youth on those hinges with MacGuyver like resourcefulness.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2007
    Awesome!!! Richie, you need to move closer to where I live!!!
  • chriskauffman
    chriskauffman Posts: 1
    edited June 2013
    My Sony turntable (PS-LX3) has the same hinges. I discovered a fairly simple fix for you do-it-yourselfers. Drill a hole on each side of the plastic portion just above the pin and insert an additional pin that retains the spring.
    Photos at http://flic.kr/s/aHsjFDvoa4
    (Ignore the hole I drilled in the center of the hinge, that was a fix that was unsuccessful)
    There is more information on the problem at the following URL:
    http://www.diyaudio.com/forums/analogue-source/156092-lid-hinges-linn-lp-12-thorens-sony-turntables-repair-orig-brand-wanted.html
  • mk8
    mk8 Posts: 1
    edited October 2013
    what kind of "pin" do you use?
